Hi! I am working in Paintshop ProX4 and am trying to go into "channel mixer" ("adjust" menu on main toolbar, and then "color") to select "monochrome" but I keep getting this message:" Command execution failed, the attempted operation is not valid in the current program state". Can someone tell me what is the problem and how do I fix it?
Thanks!
Command execution failed message in ProX4
jaws231
- motherboard: Hewlett-Packard p7-1045
- processor: Intel Core i5-2390T CPU
- ram: 8.00GB
- Video Card: AMD HD 6450 512 MB DDR3
- sound_card: IDT 92 HD 73 E audio
- Hard_Drive_Capacity: 3.44 TB
- Monitor/Display Make & Model: HP 2511 Series Wide LCD Monitor
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Re: Command execution failed message in ProX4
If I recall correctly from previous experience, that is a dialogue you get when the image you are working on is in a state that the filter you are choosing is not able to apply its effect on. Unfortunately I cannot remember what I was doing or what effect I was trying to apply when I first saw that warning. Does this happen with every image on which you attempt to use the Color Mixer or just on a particular image? If the latter, could you provide details of that image - i.e., color depth, raster or vector layer, any selections present, etc.? That might jog my memory regarding what caused me to see the warning in the past.
JoeB
Using PSP 2019 64bit
JoeB
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
Have you tried Layers>New Adjustment Layer>Channel Mixer instead?
I use X8, I no longer have X4 installed, so can't verify if it's the same, but it should be.
Joëlle
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
