Error Corel VideoStudio Ultimate X8 after upgrade
AlexL03
motherboard: ASUS P8H61
processor: IntelCore i3 2120
ram: 4 Gb
Video Card: Radeon HD6670
sound_card: built-in
Hard_Drive_Capacity: 500 Gb
Monitor/Display Make & Model: LG 1950B
Corel programs: -
Post by AlexL03 »
After the upgrade, Corel VideoStudio Ultimate X8 to version 18.6.06, constantly fails:
Signature of the problem:
Event name problem: APPCRASH
Application name: vstudio.exe
Application version: 18.4.0.27
The timestamp of the application: 565414dd
Name of module with error: StackHash_2569
Version of module with error: 6.1.7601.23250
The time stamp module with the error: 56258e3b
Exception code: c0000374
Offset exceptions: 000c31eb
OS version: 6.1.7601.2.1.0.256.1
Language code: 1049
Additional information 1: 2569
Additional information 2: 2569e281a35991cf45293acb90b7223e
Additional information 3: 8280
Additional information 4: 828001ddbe6caa8d89b552377504c811
In the message log Windows, the following entry appears:
The name of the offending application: vstudio.exe version: 18.4.0.27, time stamp: 0x565414dd
The name of the offending module: ntdll.dll version: 6.1.7601.23250, timestamp 0x56258e3b
Exception code: 0xc0000374
Offset error: 0x000c31eb
The faulting process ID: 0x1524
The start time faulting application: 0x01d13e7af76b0e54
Path faulting application: C:\Program Files\Corel\Corel VideoStudio Ultimate X8\vstudio.exe
Path faulting module: C:\Windows\SYSTEM32\ntdll.dll
Report ID: 45ebeb82-aa6e-11e5-92da-c860009d6b6a
Reinstall Corel VideoStudio Ultimate X8 gives nothing...
Re: Error Corel VideoStudio Ultimate X8 after upgrade
And welcome to the forums
When you re-installed the program did you choose to remove all personal data when uninstalling.?
Try resetting the program by renaming the folder “18.0” to “18.0_old”
Here:-
C:\Users\User Name\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro\18.0
The folder is hidden by windows explorer so change the folders view options.
Or type %appdata% into the computers Start Search panel to fine the roaming folder.
Run the program and a new 18.0 folder will be created , takes a while to launch on first attempt.
AlexL03
ram: 4 Gb
Corel programs: -
Post by AlexL03 »
Install the program Corel VideoStudio without uninstalling the current version ?!
I don’t understand what you are trying to do.
You cannot install two X8 programs on the same pc.
Once X8 is installed trying to re-install will prompt an uninstall.
Did you try re-setting the program?
AlexL03
ram: 4 Gb
Corel programs: -
Post by AlexL03 »
I want to say that first I have uninstalled the program completely with all the components with the help of Your Uninstaller PRO, rebooted the PC and then again install Corel VideoStudio...
zaphodikus
motherboard: ROG-X570-F-Asus
processor: AMD 3950 - 16 core
ram: 64Gb
Video Card: AMD RX 6700
Hard_Drive_Capacity: M2 1TB
Monitor/Display Make & Model: 4K BenQ
Corel programs: VS 2023 Ultimate, Painter 2020
Post by zaphodikus »
Just to confirm. You are upgrading from 18.4 to 18.6? And running the 32-bit installer?
Sorry the silly question, I hope it helps us figure this through.
For 64 bit
There is only Video Studio 8.0 original release and 8.5 after service pack installation.
Although I believe current purchases are 8.5, but still require a service pack SP3
Installing service packs usually change the version number, currently 18.6.0.6
If you reinstall the program check this number via the Help About before installing the SP3, then check again to compare.
I assume 32 bit would have the same numbers, can you check the version number via Help - About
AlexL03
ram: 4 Gb
Corel programs: -
Post by AlexL03 »
zaphodikus wrote:Just to confirm. You are upgrading from 18.4 to 18.6? And running the 32-bit installer?
No, after you install Corel VideoStudio Ultimate X8, software version 18.0.0.181. Then I install the update SP3 software version changes to 18.6.06.
AlexL03
ram: 4 Gb
Corel programs: -
Post by AlexL03 »
lata wrote:Hi
For 64 bit
Yes. After SP3 upgrade, the software version is changed to 18.6.06. The bit width of 32-bits. I think to remove the program and install all the updates in order starting with the oldest.
Hi Alex
Re-install the program, when you uninstall choose to remove all personal files.
First you may wish to backup the library via Settings library manager - export library
After installing allow the program to automatically update, do not install SP's manually.
The auto update may only install SP-3, at least that's what happens when I re-install.
AlexL03
ram: 4 Gb
Corel programs: -
Post by AlexL03 »
lata wrote:Hi Alex
Thank you... will Try, but later. In the next theme found theme with such a question is not one I have a problem.
http://forum.corel.com/EN/viewtopic.php?f=1&t=58301
Maybe the developers will release a fix soon...
Hi Alex
We do not work for Corel, we are volunteers running the forum to help users with their problems.
If you wish developers to know about this problem you should contact Corel Support, Corel also have a Facebook account that as far as I know is staffed by Corel employees.
First try a clean install to see if that fixes your problems?
AlexL03
ram: 4 Gb
Corel programs: -
Post by AlexL03 »
lata wrote:Hi Alex
Unfortunately, my version of Corel VideoStudio is devoid of technical support...
AlexL03
ram: 4 Gb
Corel programs: -
Post by AlexL03 »
lata wrote:Hi
Here:-
Renamed the folder to "18" in "18_old". When you run the program you created the new folder, "18", but the program Corel VideoStudioне start and does not start...
Hi Alex
I did a search for ntdll.dll and found this info
http://answers.microsoft.com/en-us/wind ... 4b6?auth=1
I don't really understand much about it, but maybe a read and a further search may help.
By the way I have passed details of this and other posts regarding SP3 issues to Corel, hopefully they will reply / help?
