Cannot start the capture graph
neXos
motherboard: Gigabyte H97-HD3
processor: Intel i5-4460 3.20GHz
ram: 4 GB
Video Card: AMD Radeon HD 6670
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: AOC 2243W
Corel programs: Corel VideoStudio Pro X6
Post by neXos »
I have VS PRO X6.
On my old computer everthing was great.
Now i upgraded to a new computer.
Installed the capture card (avermedia ezmaker gold pci driver), Installed the PRO X6 and -
"Cannot start the capture graph"
I googled for similar cases but found nothing from the past years.
Only here, but did not found any solution..
Any ideas?
Thank u.
Re: Cannot start the capture graph
I suspect it could be the driver which may not work with Windows 10. Did you ever update the driver on your old computer? The most recent driver I could find after a quick search is from January 2014 and is compatible with Win 8/8.1 so should notionally be compatible with Win 10: http://avertv.avermedia.com/Product/Pro ... b=APDriver But you might need to search the Avermedia site yourself to see if there is a more recent Win 10 driver.
The other way you could test whether it is a driver issue would be to install the editing software package which came with the card -- was it Cyberlink PowerDirector 9? If that will work under Windows 10 and capture from the card, you could always use it to capture then open the captured video in X6 for editing.... Although some users report no troubles using VS X6 in Windows 10, Corel itself felt that even X8 was not fully compatible with Win 10 and brought out an update for it to make it fully compatible. However, they will not do that for X6 or even X7.
neXos
ram: 4 GB
Post by neXos »
Well -
Now I have the pro X8 (updated) and still I get the "Cannot start the capture graph" error.
I can see the video in the Pro X8. It's the capture action that make all the trouble...
I can only again suggest trying to capture with the software which came with the capture card then edit the captured video in VS. The fact of the matter is that there are many cards out there which only work properly with the software supplied with them. The card manufacturers won't share their "trade secrets" with other software makers, but will tweak one particular package to work with their card.
neXos
ram: 4 GB
Post by neXos »
I captured video with that card and with VS x6 on my old computer (windows 7)
It worked perfectly.
Now i have a new computer (with a new windows 10) with the same video card and i cant capture
So i dont think it's the card not working properly with th coral VS..
Thank u for your time..
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
It could be that the old version of vs6 does not work with windows 10.
neXos
ram: 4 GB
Post by neXos »
That's why i upgraded to vs8
Still the same error.
