Why can't PSP give me a black to white gradient?
- gbotes
- Hard_Drive_Capacity: 500Gb
- Corel programs: Paint Shop Pro X8, Aftershot 2
I seem to be having difficulty getting PSP X8 to give me a gradient from pure black to pure white. All the gradients I've tried to create, and including using the default gradient, only gives me shades of gray with no pure black and not pure white. Generally I'm finding working with gradients and the PSP color wheel extremely frustrating. What am I missing?
EDIT: For now, I've used Photoshop Elements to create this gradient, so I have a temporary solution. But I'd still like to know how to do it in PSP.
Cassel
- ram: 16Gb
- Corel programs: PSP 8 (JASC) to PSP 2023
Re: Why can't PSP give me a black to white gradient?
If you go from pure white, to pure black with a gradient, isn't it normal to have shades of grey in between?
I am a bit puzzled to imagine how you get a black/white gradient without grey.
Cassel
https://scrapbookcampus.com
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
Here is a black-white gradient with bands of black and white at the ends to emphasize that those are the colours used.
Mark
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
gbotes, are you able to export the Photoshop gradient? PSP can import Photoshp gradients. Or give us a picture of the setup in Photoshop Elements to see what you're driving at?
- gbotes
[quote="MarkZ"]Here is a black-white gradient with bands of black and white at the ends to emphasize that those are the colours used.
On my PSP X8 I get the shades of grey but with no black or white at the ends. It's a puzzle for me. I thought maybe I'm missing something I'm supposed to do.
Here is what PSP X8 gives me: But this is what I want:
- gbotes
You're quite right, Cassel. I guess I'm not being very concise. I'm trying to get PSP X8 to give me a gradient from black through the shades of grey to white, but it is only giving me shades of grey. I'm trying to figure out what it is that I'm not doing right. In Gimp and Photoshop Elements I get it without any problems, but PSP has me stumped.Cassel wrote:If you go from pure white, to pure black with a gradient, isn't it normal to have shades of grey in between?
- gbotes
Ahem...
Thanks Cassel and MarkZ for your responses, without which I would not have been spurred to keep going at it,
I'm embarrassed to say that I have just figured it out. PSP X8 has blend modes for gradients, which I have not encountered before. Mine was set to soft light, instead of normal. This simple setting is what made the difference. Changing it to normal has produced the exact gradient I needed.
Ta-da: At least I knew I was missing something. Now, running this gradient through posterize produces this, exactly what I need to get the Zone System tones:
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Hi Gbotes,
you may use the "Grey chart" script.
I have created the "Grey chart" script for Jasc during the PSP 8 Beta Test, years ago.
Now, this script is embedded in each version of PSP until now.
You may modify it to suit your needs.
Best regards,
Jean-Luc
Best regards,
Jean-Luc
Kathy_9
- Hard_Drive_Capacity: 2TB
Best regards,
Jean-Luc
Since you created the script, you'd be an excellent person to ask for an example of how the script would be used. I remember clicking on it to see what it would do and wondered how I might use it.
Thanks,
Kathy
Jean-Luc
Hi Kathy,
Corel itself should give some explanation about the scripts available when you buy PSP !
Those scripts are owned by Corel. The Help file should give information about those scripts, what they do, etc.
After you have applied the Grey chart script, you will have a chart of greys on your screen.
Those shades of grey may be used to verify if your screen has a correct setting in luminosity and contrast.
If the settings of your screen are correct, you will be able to see all the shades on the extreme left and right.
If not, you need to correct the settings of your screen.
For example, if you don’t see a difference between R0 G0 B0 and R8 G8 B8, your screen is too dark or has too many contrast.
Kathy_9
I totally agree that a brief description of what the script does would be helpful.Jean-Luc wrote:Hi Kathy,
Corel itself should give some explanation about the scripts available when you buy PSP !![]()
This is the part I was missing; thank you for the clear explanation. I did run the script and saw the chart but then thought "now what"? Now I know.Jean-Luc wrote: Those shades of grey may be used to verify if your screen has a correct setting in luminosity and contrast.
Jean-Luc
Hi gbotes,gbotes wrote: Now, running this gradient through posterize produces this, exactly what I need to get the Zone System tones:
how do you work with it to get the Zone System ?
Just curious...
Jean-Luc
Hi Kathy,Kathy_9 wrote: This is the part I was missing; thank you for the clear explanation. I did run the script and saw the chart but then thought "now what"? Now I know.
you may also see in PSP :
-> File
-> Color Management
-> Monitor calibration
But, to be honnest, I have not found precise explanations on how to manage the color management in PSP!
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
That's why it's best to just turn it off.Jean-Luc wrote:you may also see in PSP :
-> File
-> Color Management
JoeB
Using PSP 2019 64bit
JoeB
Jean-Luc
could you explain how you use your shades of gray with "Zone System tones" ?
Thank you,
Jean-Luc
