vsp file refuses to link
frontierrots
operating_system: Windows 8.1
processor: Intel Pentium CPU N3530
Post by frontierrots »
I have a vsp file that contains the opening, intro and closing parts of my videos. I have it saved on a removable hardrive as a vsp file. I start every video with this file and have done 10 videos using it
HOWEVER, today Opening Video studio X8 and opening this to start a new video it tells me it cannot relink a file that it does not exist.
However it clearly does exist
How the heck do I get this to work?
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: vsp file refuses to link
Post by RobertOZ »
What happens if you double click on the titleclip.VSP file, this should open VS and display the file, if it doesn't, that could indicate that the file has become corrupted
frontierrots
the VS opens up. the music file appears in the music line but the video and title animation are blank and says cannot link does not exist. BUT all the other parts are fine. Like in the file that says titleopeningclosing and the one that says titleanddrone all other portions work it is njust the beginning that says won't link
RobertOZ
Post by RobertOZ »
It's unfortunate that VS does not provide the .ini files with the .vsp files, if it did (like some other NLEs do) you could actually check each component of the file.
If you right click the >vsp file and open with notepad, you might be able to locate the missing content and see if you can locate the path.
You could also try opening a project that contains that opening intro, then delete everything after the intro, then save the intro as a new project, that should get you going again, but if the file is corrupted, then all your previous .vsp projects containing the intro will also require relinking
frontierrots
tried that and the very first segment is blank in all of them so that small bit must have corrupted yes?
RobertOZ
Post by RobertOZ »
Afraid so,looks like you will have to create that intro again, then replace the old intro in each project with the new one, bit of work involved but the only way I can see, maybe one of the mods can offer a suggestion
RobertOZ
Post by RobertOZ »
Just a thought, have you created any Smart Packages of projects containing that intro, if so, you may be able to retrieve it
Post by BrianCee »
with one of your earlier projects in the timeline showing missing files - have you tried going to "File >> Relink" which will normally give you the option to link to the files again.
frontierrots wrote:the VS opens up. the music file appears in the music line but the video and title animation are blank and says cannot link does not exist. BUT all the other parts are fine. Like in the file that says titleopeningclosing and the one that says titleanddrone all other portions work it is njust the beginning that says won't link
what version of Video Studio are you using, maybe I missed that? yep I did --- X8
Can you provide an image of the error message.
and can you zip and attach the VSP to your post
