X8 Mesh Warp defect ?
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
Do you observe the same problem ?
I create an empty layer above a white background layer.
I trace a rectangle on this empty layer, full yellow color inside, no border.
I transform this layer in raster layer.
I deform the rectangle with the Mesh Warp Tool:
X8 mesh warp in work.png (10.48 KiB) Viewed 4112 times
After I apply the deformation, a tiny black border is visible around the yellow (should not):
X8 mesh warp after apply.png (10.06 KiB) Viewed 4112 times
The traced yellow rectangle doesn't have a black border.
Thank you for testing...
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Re: X8 Mesh Warp defect ?
Post by Radim »
I tried in PSP X7 and everything is fine as it should be.
Screen - http://i.imgur.com/Tlf9j9M.png
EDIT: You are right. I do not press apply. So this is a nasty bug.
EDIT 2: I tried uncheck "quality" button and violá - look this http://i.imgur.com/F4qQVEL.png
Jean-Luc
Post by Jean-Luc »
Goog catch Radim !
But the black border should never be added ..., in normal or better quality.
Just tested in X7 and the problem is also visible there after doing Apply and Better quality checked.
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
This bug goes all the way back to PSP8.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
general_error404
motherboard: ASUS H61M-A
processor: Intel Core i7-10700
Video Card: GeForce RTX 2060
sound_card: onboard
Hard_Drive_Capacity: 5TB
Monitor/Display Make & Model: LG
Corel programs: PaintShop Pro 2021, 2019, x6, x9
Post by general_error404 »
I can report this still happens in 19, 21. Thank you for the work-around.
Using PSP 19, 21
