Object Extractor
carl365
operating_system: Windows 8.1
motherboard: Dell Inspiron
processor: Intel i5-3330 3GHZ
ram: 8 GB
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Acer
Corel programs: Paintshop Pro X8
Object Extractor
Post by carl365 »
On most photos with complex backgrounds, extractor leaves fragments and transparent areas around the image, plain background subjects are OK. Is this just the nature of object extractor?
Thanks!
JoeB
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: Object Extractor
Post by JoeB »
carl365 wrote:On most photos with complex backgrounds, extractor leaves fragments and transparent areas around the image, plain background subjects are OK. Is this just the nature of object extractor?
Thanks!
Basically, yes. It all depends on the complexity of the object you're trying to extract and the complexity of the background you're trying to extract it from. There a quite a software programs and plugins available to extract objects and some work better than others as well as some working better on some types of images and others working better on other types of images. As I understand it (and I stand to be corrected) these things use algorithms that attempt to identify various elements of the object to be extracted such as color, edge contrast, contiguity of elements, etc. These programs also have varying abilities to use anti-alias and/or feathering to try to make the object extract with a smooth rather than jaggy look. When the background is relatively uniform and the object to be extracted "stands out" (to put it simply) from the background then most of these programs have no trouble discerning what is object and what is background. And most of them have some degree of difficulty with very fine parts of an object like strands of hair, etc.
JoeB
Using PSP 2019 64bit
brucet
Post by brucet »
Most times it involves a lot of work to get it right. I've tried many approaches. In the end I settled for Freehand Selection using Point to Point. Feather and Smoothing on 1 or 2. Anti Alais selected. Yes it's slow going but it's quicker than cleaning after the automatic/easy ways.
rgards
carl365
ram: 8 GB
Post by carl365 »
Thanks guys, yes I've gone back to selecting, or maybe using a mask. I guess extractor is ok for some applications but trying to fix what it did is not worth it.
