Cannot add files to library or timeline
rkstudio
motherboard: There is no motherboard listed
processor: Intel Core i7-855ou CPU 1.80 GHZ
Video Card: Radeon 540 Graphics
Hard_Drive_Capacity: 256 SSD
Monitor/Display Make & Model: Radeon 540 Graphics
Corel programs: Videostudio 2020 Pro
Post by rkstudio »
I was dragging photos to the library and everything was going just fine when all of a sudden I couldn't add any more. I only dragged about 10 photos in the library, then suddenly I couldn't add any more. I even saved the project, closed the program, then I re-opened it and I still can't add any more images to any folder in the library.
I even tried to add them to the timeline and that didn't work either. I was thinking maybe I clicked something by mistake that made it stop working. When i try to drag a photo, it just shows a circle with a slash.
Any ideas on what could have gone wrong?
BTW, I was adding them to the library, then from there to the storyboard timeline.
Is there a limit on how many photos can be added to the library?
Re: Cannot add files to library or timeline
Post by BrianCee »
If there is a limit on the number of files in the library it is quite high - we see reports here of people with hundreds of files in their libraries
what is the format of the photos which will not load - Videostudio will take quite a selection but will not accept programme specific photos like .psp or .spp
if you delete the 10 you already have can you reload them again without problem
rkstudio
Post by rkstudio »
Hi Brian,
The photos are just .jpeg's. For some reason, I can't click and drag anymore, but the work-around that I tried was I right clicked in the library and selected "insert media files", and that worked. I even shut down VS and my computer and started all over again and it did the same thing. Well I guess I'll just right click and insert from now on.
Thank you for the help.
Bob
Hi Bob
The only time I had problems with the library and Jpeg images was with a laptop, turned out the graphics driver needed updating.
Strange as it was a new laptop. I also had problems using the sample images provided by the program.
I don’t suppose you are having other problems with the library?
rkstudio
Post by rkstudio »
Hi Trevor,
It's a little strange because I was doing just fine, dragging 8 photos to the library with a couple more to go. Then suddenly, I couldn't do it anymore. Anyway, I found another way to do it...right click in the library and select "insert media files". I don't mind doing it that way, but I would still like to find out why it's doing that.
Also, no, I'm not having other problems with the library that I know of.
Oh, BTW, I don't know if this has anything to do with it, but last night was the first time I used the storyboard view, so maybe ...
