Drag & drop doesn't work to move images between folders
Bugs & Suggestions
gtwelchjr
Post by gtwelchjr »
For some reason the drag & drop function to move images in the file system in ASP 2 is not working. This feature worked in ASP 1.0 but not sure it has worked in ASP 2 that I installed about a month ago. I can drag an image to an output (ie JPEG Proof or 8-bit TIFF) fine just can't drag to another folder in the file system pane.
Have rebooted a couple of times with no change.
Any ideas on what could cause this?
ASP 2.3.0.99 x64
Windows 7 Ultimate
Tom
birgander
operating_system: Linux
System_Drive: N/A
Re: Drag & drop doesn't work to move images between folders
Post by birgander »
Same for me. Seems to be a genuine feature of Aftershot 2.3, since it was working fine in prior versions... In fact this bug is extremely annoying, I cannot sort my files into their final folder anymore, so tagging them becomes pretty useless.
ASP 2.3.0.99 x64
Linux (openSUSE Leap 42.1)
BE
gtwelchjr
Post by gtwelchjr »
BE like you I used the drag & drop to sort images into directories and it is very annoying that that function seems to be gone.
I did discover that if you import the directory and create a catalog the drag and drop functionality can be used.
I noticed that BE is also using the 64 bit version of ASP and was wondering if the 32 bit version functioned the same way.
If the absence of the drag and drop in the "File System mode" is truly a changed feature in ASP 2.x then I wish someone would post a comment stating that.
Tom
jknights
operating_system: Mac
motherboard: Apple
processor: Intel 3.08GHz Dual processor Quad Core
ram: 24GB
Video Card: ATI Radeon X1600
sound_card: Intel HDA
Hard_Drive_Capacity: 6TB
Monitor/Display Make & Model: Apple Display
Post by jknights »
I am becoming increasingly irritated by the loss of drag'n'drop in the file structure browser in AftershotPro. They really need to fix this ASAP.
This seems to be broken in all platforms. It has been reported on Windows, Mac and Linux!
Come on Corel, you have managed to update the ASP to support many of the new cameras dont spoil the improvement by not fixing this fairly vital function.
Still learning after all these years!
bear_sk
System_Drive: N/A
Post by bear_sk »
Same for me (Fedora Linux 20-23 - 64bit), does not matter, if it is JPG, RAW, local disk or network disk. This persist at least 9 months.
bear_sk
System_Drive: N/A
Post by bear_sk »
Still not fixed in 2.4.0.119 x64:-(
jknights
motherboard: Apple
ram: 24GB
Post by jknights »
bear_sk wrote:Still not fixed in 2.4.0.119 x64:-(
Agree. Still broken on Mac with ASP v2.4.0.119 x64
:evil: :roll: :twisted:
twan052
System_Drive: N/A
motherboard: Gigabyte GA-z87x-udh3
processor: Intel Core I7
Video Card: Intel HD4600
Hard_Drive_Capacity: 3TB
Monitor/Display Make & Model: Dell-u2713h
Corel programs: Aftershot Pro
Post by twan052 »
A quick overview of the latest update 2.4.0119 ASP installed on MAC OS X 10.11.2 El Capitan.
What does not work:
- Moving files in the file system tab (Drag and Drop)
Serveral Plugins not available in plugin tab in MAC version 64 bit.
Zone
Grid
Mix3
Bez-Tools for manipulating tonality
Silicon Bonk-New generation Black & White
Also I tested version ASP 2.4.0.119 on Windows 10 64 bit.
- Same problem with Drag and Drop files.
Plugins on Windows 10 (64bit) system , all 64 bit plugins are available and working as far as I can see.
Unfortunately for my MAC 10.. 11.2 (El Capitan) I go back to version 64 bit version ASP 2.1.1.10
everything is available and working,as in Windows 10 64, except the Drag and Drop problem.
So Corel do something with this information.
What also miss,is the Gradfilter plugin.
Kind regards,
Twan
