Today it advised me of the update , I allowed it and here we are again. program stopped and needs to close.
If it ain't broke DON'T FIX IT!
Hi Karebai, we are sorry to hear so many issues that you met after updating SP1. It should not happen as it is and we are expecting to figure them up with you together ASAP. If you do not mind, would you mind to describe each issue you mentioned in detail? Like "reproduce step", "reproduce rate"...etc. Current description you wrote in the forum is too rough and we cannot duplicate them from our side correctly. If you can take your time to share more information with us, it will be great!!karebai wrote:X8 SP1 decided to install today as soon as I opened PSP. I have updates set NOT to auto update so I can watch what happens with patches etc before I install them. (I have had bad experiences in the past with patches/updates). Upon checking my system I have found the Corel Update Helper installed .... I did not give permission for this !!!.
So, now with the "update" ... preferences were changed, in particular, workspace setup... grrrrr .... fixed that. OK .... have work to finish up 1 image before I go out. Now I can't feather a selected area after removing the background. I have tried every setting I can think of. Have another machine still running WIN8.1 with PSP X5 .... not a problem finishing the work on that system ....
So what else has the "service pack" broken/updated ?
File tree under "File" .... bottom of the table disappears and changes as I mouse over ... can't do screen cap as it changes ....
I'm still trying to find if anything else has been "updated"
Thanks Corel
Thank you Joseph, I hope so - as this is happening on my laptop here are some system, specs -josephlin wrote:Hi Karebai, we are sorry to hear so many issues that you met after updating SP1. It should not happen as it is and we are expecting to figure them up with you together ASAP. If you do not mind, would you mind to describe each issue you mentioned in detail? Like "reproduce step", "reproduce rate"...etc. Current description you wrote in the forum is too rough and we cannot duplicate them from our side correctly. If you can take your time to share more information with us, it will be great!!karebai wrote:X8 SP1 decided to install today as soon as I opened PSP. I have updates set NOT to auto update so I can watch what happens with patches etc before I install them. (I have had bad experiences in the past with patches/updates). Upon checking my system I have found the Corel Update Helper installed .... I did not give permission for this !!!.
Thanks Corel
I can see that the results you got as your last statement says can be quite concerning.The Pathfinder wrote:I have tried both ways SP1 from within the program and SP1 from the link Corel provided, no AV running during install no other programs running.
SP1 installed fine on my laptop but not on my desktop, and on the desktop I get the same result each and every time SP1 is installed, I dont care about the text missing from the splash screen the fact the the drop down menus no longer have any text is the real issue.
There is nothing special about my machine and I have never had any issues installing software on it.
The fact that tech support provided instructions about doing a repair which is an option that is not offered when following there directions is quite concerning.
Good thought. Using a Restore Point prior to its first installation would be helpful to try, but most people who have issues likely have made other changes since then that would make that either impossible (no such point now exists) or very inconvenient to do.Bobby55 wrote:... therefore I conclude that sp1 leaves traces that cannot be removed by the cleanup tool.
That's because the version of Perfectly Clear that comes with PSP is not the full version. It does most of what the full version does but is missing a few filters. If I recall correctly that includes some stuff to do with Beautify. You need to be able to install the version that came free with PSP, not the one from their site.Bobby55 wrote: I contacted Athentech explaining the issue. They suggested uninstalling Perfectly Clear from control panel and download from their website. This I did and installed, IT WORKED, however it is a trial version and requires a purchase which is way out of my budget.
