Cant find Boris Graffitti in VideoStudio X7 FX menu
Roddey_Phipps
Post by Roddey_Phipps »
I have version 6.1 of Boris.
It shows up exactly where its supposed to in VideoStudio Pro X6
but not at all in VideoStudio ProX7
How do I get Boris Graffitti to show up in Video Studio X7 FX?
thanks for any help
Re: Cant find Boris Graffitti in VideoStudio 7 FX menu
First check in the vft_plug folder of your X7 installation in Program Files to see if there is a file Graffiti6.vft... If it is there but not showing when you open X7, then try going to C:\Users\[Your Name]\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64) and changing the name of the 17.0 folder to something like 17.0_OLD. Then reopen X7. It will build a new 17.0 folder and hopefully Boris will now show.
If Graffiti6.vft is NOT there, then you have a couple of choices. The first is to reinstall the Boris plug-in from your X7 installation files. Or you can copy that file from X6 and simply insert it in X7 (after first checking it says Graffiti6 and not some other number -- sorry but I don't have X6 on this computer so cannot check). When you open X7 it should now show, but if not then you will need to go through the renaming of 17.0 process outlined above.
Roddey_Phipps
Re: Cant find Boris Graffitti in VideoStudio X7 FX menu
thank you, this worked!
very helpful
It might be helpful to others if you could tell us which aspect of my answer worked for you...
Roddey_Phipps
found this in the X6 plug ins folder
Graffiti6.vft
copied and pasted it to the X7 plug ins folder, restarted, BOOM, all good to go.
