Selecting black text for improvement?
terrypin
motherboard: Asus Z170 Pro 4
processor: Intel Core i7 6700K 4.0GHz
ram: 32 GB
Video Card: None - uses built-in graphics
sound_card: HD onboard sound card
Hard_Drive_Capacity: 4.256 TB
Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
Post by terrypin »
Quite often I capture a small part of a map which would look satisfactory when shown full screen if it wasn't for the poor text. Here's a typical example:
I'm sure I could make some progress with this if I could somehow select all the text. (And other black pixels too, like tracks and road edges, as they would also benefit from improvement.)
I'd like to remove the text blurriness, so that it looks as close to 'normal' as possible, as in the small example here:
Any suggestions on how to do this in PSP8 would be much appreciated please.
The example is uploaded here:
https://dl.dropboxusercontent.com/u/401 ... Text-1.jpg
Terry, East Grinstead, UK
Using PSP 8 & PSP 2018 under Win 10
Grazie
motherboard: Asus TUF X299 MK 2
processor: Intel Core i9 10900X s2066
ram: 64gb
Video Card: EVGA RTX 3080 XC3 Ultra 10GB
Re: Selecting black text for improvement?
Post by Grazie »
First off, how did you capture your image? Scan or what? What Reso did you scan with?
Secondly, I tried with 5 Compositing Layers in X8. This any good?:
View of Layers:
G
terrypin
ram: 32 GB
Post by terrypin »
Thanks Grazie. To get an image like that previous example I zoom in on an area in my mapping program and use Snagit to capture it. Here's another:
https://dl.dropboxusercontent.com/u/401 ... Text-5.jpg
which you see is 1611 x 1058. I might then crop it a bit before using it as part of a video.
Your result looks great, but can you step me through it please? How did you make those 'compositing layers'? What did you do to them? In PSP 8 I have these options for my background layer:
Grazie
ram: 64gb
Post by Grazie »
Hi Terry,
I created the Project in Corel X8. Now that I'm realizing that you use PSP8, I saved a COPY in PSP8 Compatible. Let's see if that works. Once you open it up make sure you are pointing the Project file to your SOURCE image, the one I used may just be part of the Project automatically already, you can then view the layers AND the various Compo Modes I used. Look at the "ordering" of the copies of the image and the type of Compo I used. All these terms have their feet firmly rooted to the Print industry, and as such have had their "digital" equivalent now as part of Photo s/w and NLEs for video editing too.
Here is the PSP8 Compatible Project file : https://dl.dropboxusercontent.com/u/203 ... 8.pspimage
G
terrypin
ram: 32 GB
Post by terrypin »
Thanks Grazie, I now see what you've done. Bit of a revelation for me. I'm a relative novice despite many years as a PSP8 user and have never used the 'Blend mode' feature before. The few times I've attempted to study it I've been daunted by its complexity and given up!
Therefore I'm assuming it's your skill and experience that got you that result. I calculate there are over 490 million possible ways of working on a background plus five copies using only blends. (21 blend options to the power of 5, times factorial 5 for the ordering.) That's not even allowing for further trial/error with opacity levels, where I see you've adjusted 3, presumably by trial/error?
But I'll try (blindly!) to reproduce that exact pattern with another map extract . If successful and it proves amenable to a recorded script then that could indeed be a practical solution for future map extracts. :)
