"Add to swatches" = " Swatch Cannot Be Created"
JohnWalker
motherboard: Foxconn 2ADA 1.00
processor: 3.10 gigahertz Intel Core i5-2400
Video Card: NVIDIA GeForce GT 620
Monitor/Display Make & Model: Gateway LP2417
Corel programs: PaintShop Pro X5 15.3.0.8
Post by JohnWalker »
I am using PSP X5 (15.3.0.8) to try to create a new Pattern Swatch from a flattened image. (Single layer, no vectors.) The particulars:
- 512x512 Pixels
- 72 PPI
- RGB 8 bit
I click on the foreground in Material Properties, select the Pattern tab, select my image, and then click on "Add to swatches..." whereupon I am consistently presented with:
"A swatch cannot be created from this material for the following reason(s):
The pattern has not been saved."
I don't know if the second line of text is the reason (the file is saved), or if the real reason is supposed to appear where the blank line is.
I can add Color and Gradient swatches just fine. I restarted the app several times, even As Administrator.
I suspect that I am missing something blatantly obvious, but turned up nothing even after a good couple of hours of reading everything even remotely related online.
I will be grateful for any ideas.
