Changing value of input fields with non english locale
Bugs & Suggestions
dannysatan
operating_system: Linux
Corel programs: AfterShot 2 Pro
Post by dannysatan »
I wanted to change the values in the text inputs just next to Autolevel label (0.2 and 0.2 by default) but it kept on staying set to 0.000
What I realised is that my Windows locale setting for number formats is set to Polish where decimal separation point is a comma and not a dot. I had to change my locale to English(UK) in order to use this feature at all. It probably affects all the other numeric fields in Aftershop but I didn't check.
Cheers,
Daniel
transeuropa
Re: Changing value of input fields with non english locale
Post by transeuropa »
Yes, sure - all input fields are affected (on all operating systems)
Thx Daniel for unveiling the culprit.
Solution for Linux is to change LC_NUMERIC environment variable to e.g. en_US.UTF-8
Unfortunately this solution does not work on Mac OS X because this variable controls only terminal application. You have to change the global setting in the system setting dialog Language & Region.
Incredible that no one complains before. Personally I worked until now with ASP 1.2 - does anyone uses ASP2 outside of UK/USA?
Cheers,
Harald
dannysatan
