Hi - all of a sudden my X8 Layers button along the top is missing.
Is there any way to retrieve it without uninstalling and reinstalling?
Thanks,
Marj
X8 Layers button
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: X8 Layers button
Yes, two main ways in fact.
1) Reset the menu
or
2) Reset the entire workspace.
To reset the menu, go to the Customize dialog under the View menu
View -> Customize
Click the "Menu" tab on this dialog. You'll see a section labeled "Application Frame menus" that is set to "Default Menu" Click the "Reset" button. This will reset the entire default menu system back to normal. So no more missing areas....and any customizations you did will be lost. But easily re-made.
To reset the entire workspace -
Close PSP. Then reopen PSP while holding the SHIFT key. It'll ask if you want to reset PSP back to factory defaults.
Once your have the workspace back to the way you like it. Save the workspace by going to File -> Workspaces -> Save.
Once the workspace is saved, you can reset back to this workspace by going to File -> Workspaces -> Load.
1) Reset the menu
or
View -> Customize
Thanks so much LeviFiction.
All fixed!
Don't know what I'd do without this Forum!!!
Marj
All fixed!
Marj
MARJ
