Convert step got some problems [257:0:0]
MIKEL
- motherboard: ASUS P6X5bl Premium
- processor: Intel i7 930
- ram: 24GB
- Video Card: NVIDIA GEForce 8500
- sound_card: Built in 5.1 surround
I tool four clips using a Canon 7D mkII - they were of a band at a birthday party so no editing was done.
When creating a DVD or a file I get an error message - CONVERT STEP GOT SOME PROBLEMS and what I assume is an error code [257:0:0]
The problem is probably with a part of the video clip and I would appreciate any help in understanding how to find the section that is confusing X7.
I would have assumed a better way the application handles the problem.
Can't complain too much as this is the first time in years I have a problem I couldn't solve.
I will create files from each section and find the bad one - but it be a pity the app couldn't be more precise.
thanks
Mike
thanks
Mike
Many thanks
Mike
Mike
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Re: Convert step got some problems [257:0:0]
Are you going straight from the timeline to dvd, most people will actually make a video file first, then start a new project and make the dvd from this new file.
If you can't make a file from the three files, you will need to do what you are doing and try resaving each one to see if one or all fail.
MIKEL
- ram: 24GB
Thanks Graham - this was a quick favour - but I am making files and so far two fail out of five.
What do people that know what they are doing do? It is an interesting "happening"
My way is to lop off the ends of the errant file or one at a time and hope for the best.
Is there a way of finding the problem? If nothing more than out of interest and find out why so I can miss this annoying waste of time in the future.
Mike
Mike
Many thanks
Mike
Mike
MIKEL
- ram: 24GB
Seeing I am not the best explainer on earth please let me add
I took the files with a Canon 7D mkII and they play fine even on Video Studio X7 - just some clips start to render into a file and when they get to the end 99% they just drop dead and the temp files in the target folder dissapear.
So annoying.
Mike
So annoying.
Mike
Many thanks
Mike
Mike
While your files from the Canon should work fine with VS, one thing you could try would be to use a video converter program to make a new file with the same properties. You haven't told us the exact properties of these clips, but I am assuming they are probably some form of AVCHD mpeg-4. But it would be useful to confirm: so can you right click on one of them in the VS timeline and copy ALL the Properties here, or take a screen grab of the Properties box and upload it here as an Attachment.
Some of us use a video converter called Format Factory which works fine -- though you need to be careful when installing as it offers to install all sorts of other unwanted things, like toolbars etc.
But once installed, set it to convert using high quality AVC settings. If Format Factory has a problem converting your video, then there is definitely something serious wrong with it!
MIKEL
- ram: 24GB
Hi Ken wow the last time you helped me was a lifetime ago - you were in Egypt at the time.
Anyway because of you I only remember having this amazing tripod you suggested.
Have attached a Word file with two captures - one an error message I got a few times a few days ago - maybe even a week ago.
The other is what you requested. I need to educate myself on the actual properties. I reinstalled VS to no avail - of the 5 clips only 2 work and I get file made successfully.
Isn't there any error messages? I did look
Much apprciated
mike
Much apprciated
mike
- Attachments
hangs when burning disk or making a filexxx.docx- the error msg got a few days ago now nothing.
- (57.39 KiB) Downloaded 252 times
Many thanks
Mike
Mike
Hmmm... those properties are quite normal, so nothing wrong there. Coincidentally, there is someone else just now reporting a similar problem. Please have a look at a suggested remedy there: http://forum.corel.com/EN/viewtopic.php ... 24#p316324
If that doesn't work, then you might need to think about my suggestion of using a video converter to produce a new version of your problem clips...
PS: glad you took up my suggestion about the Velbon tripod. Mine is still working well 6 or 7 years later. One of the best video-related purchases I have every made. Floating head tripod for $75 -- ridiculously wonderful!!
How large are the files in Gb.
The properties you show a duration of 1101 seconds, that’s about 18 minutes and would be over 4 Gb, I think?
Your hard drives, are they formatted to use Fat32 or NTSC.
Fat32 has a file size limitation of 4 Gb.
You said “and the temp files in the target folder dissapear.” That would probably happen if your system is Fat32
Besides I own a Canon D7, unfortunately not the mark II, but use the same video, although I don’t use the camera that much for video, I have not had any problems.
MIKEL
- ram: 24GB
Thanks Ken and Trevor
I will have a look at the workaround - I must admit it has stopped being annoying and moved up to "interesting" the highest on my scale of things.
I have 4 drives all NTSC as they are all 1TB. There is 24GB of Ram and the system drive is an SSD.
The 7D mkII has a 4GB limit on video files and just creates another clip automatically. So the largest is only 3.92GB the others are less than 1GB.
I'll follow the link now.
Thanks I really appreciate your help - seems to be the best way to meet nice people.
Mike
Mike
Many thanks
Mike
Mike
Hi Mike
As I say I use the 7D camera with no problems, however I have not recorded long video certainly not reached the 4 gb limit.
Later today I will do a quick test, maybe the Canon 4 Gb is affecting the file when editing?
If you edit smaller files, less than 4 gb do you have the same problem?
MIKEL
- ram: 24GB
As far as the workaround is concerned I use VS X7 no X8.
The file size was an interesting question - there are 5 files (1) #4758 238MB OK, (2) #4759 3.92GB bad, (3) #4760 875MB OK, (4) #4803 3.92GB bad, (5) #4804 172MB bad - almost
I tried other formats and #4804 I tried the small WMV (MOV) and that worked but so small the larger formats disn't work. Going back to "annoying"
Mike
Mike
Many thanks
Mike
Mike
Ok
I have tried rendering a 4 Gb 7D video, no problems
I converted the video to Mpeg2 suitable to burn a DVD.
Share – Mpeg2 choosing the profile ---MPEG-2 (720 x 576, 16:9, 50i, 8Mbps)
Although I would modify that to use Frame Based not Upper Field to match the original video?
MPEG files
24 bits, 720 x 576, 25 fps
Frame-based
(DVD-PAL), 16:9
Audio data rate: 384 kbps
What options do you choose after Share------
Ok
MPEG files
Frame-based
(DVD-PAL), 16:9
MIKEL
- ram: 24GB
I gave up with the DVD and tried to just create a file - mostly MPG-4
I'll give your setup a try - thanks for the help - things I don't understand drive me crazy.
Can't see what the problem is - usually it is something simple that I have just not clicked on.
Much appreciated - you spending the time
mike
mike
Many thanks
Mike
Mike
jcsaba
- processor: Intel Core i3 4130 3.40 Ghz
- ram: 4GB
- Video Card: Nvidia GeForce GT 640
- Corel programs: VS X5, VS X7
Happy New Year to everybody
I have been using Corel VS (and it's predecessor Ulead) for 13 years. Using VSX9 under Windows 10, more and more I face this problem as above: Convert Step Got Problems [257:0:0] when I create DVD with menus. (Earlier under Windows 7 or XP that never happened). Sometimes after several attempts and changes in the menu, I managed to complete the process, but this time I was unsuccessful. I even tried to complete the process with a downloaded trial VS 2020, but no success. The same happens either when I use pre-rendered mpg files (first I render my video into an mpg file, then I try to create menus and burn into a DVD image file), or when I render the video and burn it in the same session. Corel is also fully aware of this problem: https://support.corel.com/hc/en-us/arti ... t-Problems . They suggest using VideoStudio MyDVD, but this software is rubbish, I couldn't even create at an image file (iso) to fit a standard DVD despite the setting was fit DVD 4,7G (poor menu, very few editing options, my 4:3 monitor colud not even display the full screen of the software work sheet etc). What I noticed during the several attampts to burn was that the error occured when the second or third page of the menu was to be created by the apllication (I tried to create a simple 3 page non-motion menu with 9 thumbnail or text marked chapters). In the end, I found one 9 chapter menu in the Gallery, i.e. the whole menu was made up of one page. Using this one page menu the burning process completed successfully. Do you have any suggestion??
Jcsaba
Quite an old post, a little different as the OP was burning avchd.
First the attached images have quite a large white border effectively reducing the image size
If you use Alt + Print Screen that would have saved the image to the clipboard without the white border.
OK
I think you should do a test project then convert and burn to dvd
Try this
1 / Start a new Project, if you wish you can use your original project, otherwise add a load of images to create a slide show.
2 / render the project to Mpeg2 – use the profile
MPEG-2 (720 x 576, 16:9, 50i, 8Mbps) for Pal or MPEG-2 (720 x 576, 16:9, 25p, 8Mbps) where the original videos are progressive.
You do not indicate if you are using NTSC or Pal?
3 / when complete start a new project to clear the timelines, insert the video made in 2 above
4 / you should see a message to match the video files properties, yes to this.
If you do not see that message then check F6 preferences for Project - - Show Messages is selected.
5 / remove the video from the timelines.
6 / with an empty timeline choose Share Disc DVD
7 / from the burner module top left for Add Media - Add Video File, browse for the video created in 2 above
8 / Now you can create your menu
You do realise that we can customise any menu template to use different amounts of thumbnails although 9 is probably the max.
9 / first I would try creating an ISO without any chapter points
10 / when you finally hit the Burn the process will start with Convert Menu
If it starts with Convert Title then there is something wrong with the setup as the Mpeg2 is a compliant DVD file and does not need any further conversion.
Does that work ok
11 / Close the burner module, you will now save the project, call it My Burn DVD Project
12 / Opening that project again will retain the details including the menu structure, the timeline will be empty, remember to go Share – Disc - DVD
13 / modify the menu to add Chapter points, I assume as your first image
14 / again pressing Burn should always start with Convert Menu, Convert Title is a no no….
Finally you do not say if you have added any background music, I recall there being an issue when using Music with Motion Menu, so if things fail again try deselecting those options.
Now running out of ideas
OK
Try this
Does that work ok
