X8 does not refresh preview when colorize is unchecked ...
SJS
motherboard: Dell Inc 0KWVT8 A03
processor: 11th Gen Intel Core TM i7-11700
ram: 16 GB
Video Card: NVIDIA GeForce GTX 1660 Ti 6GB GDDR6
sound_card: Onboard Realtek Codec
Hard_Drive_Capacity: 4 TB
Monitor/Display Make & Model: DELL U2412M
Corel programs: PaintshopPro 2022 Ultimate
Post by SJS »
I just found a new PSP (X8) quirk when using "Colorize" in the Adjust -> Hue & Saturation window. If you have colorize checked, the preview is not correctly updated when you uncheck it (although it does change the colors...).
I may be seeing other similar problems with the preview not being updated or updated correctly as options change... but this one I can reproduce. Others?
Joelle
ram: 16 GB RAM
Hard_Drive_Capacity: 1TB
Re: X8 does not refresh preview when colorize is unchecked .
Post by Joelle »
I checked this ..
Set at default, I checked Colorize.
The Saturation slider went to 0.
I un-checked the Colorize button, it reverted to Default, the Preview window showed the default.
Joëlle
Joëlle
(PSPX9 )
SJS
ram: 16 GB
Post by SJS »
OK, just repeated this exercise:
Open Adjust Hue/Saturation/Lightness
at this point Colorize is unchecked. Settings are as Last Used, which includes Hue set to -15 at the moment, saturation at -2 along with Preview on Image checked.
Check Colorize
the preview window (and image) get colorful and the Saturation goes from -2 to 50.
Uncheck Colorize
the settings revert to Last Used, but the previews in window and On Image remain "colorized"
Joelle
ram: 16 GB RAM
Post by Joelle »
You might want to reset using the Shift key and see if that makes a difference.
Joëlle
Joëlle
(PSPX9 )
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Check Colorize
Uncheck Colorize
In my case when I check Colorise, The Hue goes to 0 and Saturation goes to 0 and I have a black and white image - no color at all.
Unchecking Colorise and all (Hue, Saturation and Lightness) revert to the previous settings. The image and After Preview window show the effect of these settings as I would expect.
This is 32 bit version of X8 on Windows 8.1
So no reproducible bug here unless I am missing something in your instructions.
SJS
ram: 16 GB
Post by SJS »
As noted, I have the setting in the "Hue/Saturation/Lightness" window set to "Last Used", I don't see this behavior if I choose "default" from the options list.
Also I am running 64bit PSP X8
