jcrous wrote:JoeB wrote:ovalseven wrote:I'm surprised I'm not finding more complaints about this. As I frequently change both the dpi and pixel size while resizing a single image,...
PSP, like all graphic editors, does not have the ability to change DPI (dots per inch). That is solely a function of printers. Graphic editors like PSP only allow you to change PPI (pixels per inch).
Joe, are you sure?
Yes.
In another thread I posted a an explanation with written examples of what PPI means and how it works which seemed to be well received. If interested you can read it here:
http://forum.corel.com/EN/viewtopic.php ... 13#p339324
jcrous wrote:Amazon and Createspace requires the cover pics to be 300 dpi. As my pics are big enough in pixels, I can enlarge the size to 300 dpi without losing quality. I change the dpi to 300 and automatically the pixels change to around 8000 x 12000. I then just set the size back to 2000 x 3000 pixels. The dpi then remain at 300 and the cover prints perfectly.
No you can't change the DPI using PSP. With PSP and any other graphic editor you cannot change the DPI of an image, only the PPI. Open PSP and go to the Resize dialogue, Print Size tab. You'll see that there is not place to set DPI, only PPI.
The reason the pixel size of your image automatically increases when you increase the PPI is because you have the option set to maintain original print size. As you increase the PPI that tells the printer that you want more pixels of the image printed on one inch of space (300 pixels per inch as opposed to only 72 of the image pixels per inch). So to maintain the original print size PSP must add more pixels to the image to allow 300 pixels of the image to be printed on one inch of paper and still print the complete image at the original size it would have printed if the PPI had been set at 72PPI but with much fewer pixels.
As LeviFiction pointed out, some people, programs and websites seem to use DPI and PPI as if they mean the same thing and are interchangeable. They don't and they aren't. If you are speaking of Amazon's requirements for them to have a cover image that is capable of being printed clearly to a certain size then they will tell you both the pixel size and the PPI required, which is usually 300. If they are only concerned about how large the image displays on their web page which lists the book with a picture of the cover then they should only be telling you what the pixel size of the image should be because PPI isn't relevant to that. In no case should they be telling you what DPI to set for the image because you can't set that. If they are telling you that then they are wrongly using DPI when they should be using PPI. If they are in the business of book publishing they should know better.
P.S. Yes, if you have a cover image that is 2000 x 3000 pixels with a print resolution of 300PPI (not DPI) then it should print a nice cover at 6.6 x 10 inches, which is a bit larger than most paperback novels but sounds like a reasonable size for trade publications.
But if you printed that same 2000x3000 pixel image at its default PPI setting of 72 it would print out at 27.7 x 41.6 inches with poor quality output but way to large for any printer paper you have.
