VS is my favorite video editor by far but once in awhile with a new version you get this problem during installation:
Following copy of the installation files to work space auto-launch of the installation fails in one of two ways:
1 - Setup briefly appears, then disappears. Installation has failed.
2 - Setup proceeds until the DirectX setup completes, then you get a message "Installer Not Completed -9" and you are dead in the water again. Re-booting does not help nor does "Run as Administrator.
After fooling with this for a couple of hours I discovered the workaround: go to where the installer files were initially written. Find "Setup.exe" and launch it manually using "Run as Administrator". Works for me. Hope this helps someone else. Easy when you know how but maddening until you discover it.
Best wishes,
K
Videostudio X8.5 "Installer Not Completed" Glitch
Klindar
- motherboard: ASUS P77 Deluxe Gen3
- processor: I7-2600K
- Video Card: AMD Sapphire 6970
- sound_card: Realtek High Definition
- Hard_Drive_Capacity: 3 TB
- Monitor/Display Make & Model: Dell U2711
- Corel programs: Paintshop Pro Ultimate, Video Studio
Re: Videostudio X8.5 "Installer Not Completed" Glitch
Thanks for that info, I am sure it will help others.
Strange how most do not have any problems yet other users simply cannot install at all?
- zaphodikus
- motherboard: ROG-X570-F-Asus
- processor: AMD 3950 - 16 core
- ram: 64Gb
- Video Card: AMD RX 6700
- Hard_Drive_Capacity: M2 1TB
- Monitor/Display Make & Model: 4K BenQ
- Corel programs: VS 2023 Ultimate, Painter 2020
In Windows 8.1 the requirement to "elevate" comes in, since the system ads some annoying security. The run as administrator trick becomes necessary if you install any program that is not called setup.exe and it happens to install a driver or service. Windows has some clever code to decide to go all admin on you; or not, and naming a file xxxxinstallxxx.exe will also help. But "Run as administrator" is a fair trick to try whenever a program install or launch fails no matter what.
