Okay, I have a DVD made from material originally on analog videotape which was captured to HD via a digital videocamera ("pass-thru").
As the DVD plays, an out-of-sync problem becomes worse and worse. At the beginning, the OOS is only a fraction of a second, hardly noticeable.
By the end of one hour, the OOS is much larger. At the end of nearly two hours, it is ridiculous -- my guests are commenting to each other. Embarrassing.
The source material is no longer available; all I have is my DVD. I didn't at first realize that the OOS problem got progressively worse. I imported the MPEG file into VS9 and split off the audio.
But how do I correct a problem that is increasingly worse? I can't just shift the audio forward a tad. That might be right at the start, but it won't be right for the latter parts of the video. What have other people done?
P4 3GHz HT, 1G RAM, 2 x160GB SATA HDs, WinXP Home, VS9 boxed
Keith
Progressively worse OOS
GeorgeBW
Hi Kebrington,
It's a tough assignment ahead of you if you are trying to re-synch sound over two hours of video. As GeorgeW says... making re-synchronising cuts at intervals is about the only option you have.
I had this problem during linear assemble editing years ago. I was forced to insert simple mask type transitions at intervals where I could cut and adjust the soundtrack in the timeline.. It worked OK.. but was very tedious, and I'm talking about productions a lot less than two hours.
I know it's not much help, but my guess is that the audio was routed thru' a soundcard during capture process, or that the original sound was mixed with the video from an audio recording. Both of these possibilities would show a symptom of logarithmic increase in OOS with the sound lagging the picture.
Good Luck
GeorgeBW
Good Luck
GeorgeBW
