I frequently capture images like this from my map application.
https://dl.dropboxusercontent.com/u/401 ... rginal.bmp
(I've uploaded what I hope is a pixel accurate image as well as the smaller one embedded here, to allow faithful zoomed colours.)
I'm trying to automate a procedure which will:
1. Remove the dotted lines.
2. Remove the numbers along both scales, but leave the outline curve and axis of the profile intact.
I eventually managed to record a script to do the first, using colour replacement, capitalising on the slightly different pixel colours resulting when I pasted my capture into IrfanView initially, before working in PSP8.
But that obviously doesn't work for the second requirement because the colours of the outline and the numbers are the same: black or close to it.
Manually it would be trivial: just select two rectangles, bottom and left, and delete, leaving the light yellow background. But doing that with a script is beyond me.
Q1: Can it be done and if so can someone get me started please?
Alternatively I turned to Macro Express Pro. I would be able to write a macro for this select and delete task (with difficulty) in just about any other application, by first determining the size and position of the window. I don't know about modern versions, but PSP8 frustratingly prevents my doing that because 'the window' is always treated as the whole PSP8 window. I've so far been unable to access any information programatically about an image window's position and size. Nor do images get displayed at a consistent position (say like flush in the top left corner), so that's no way around the navigation problem either.
Q2: Is there a script or any other clever hack that would get me the size and position please?
Meanwhile I've succeeded with a third option: removing all the dark colours then selecting all the green followed by Selection > Modify > Select Selection Borders and finally restoring an outline border. My first attempt looks like this and I may be able to fine tune it to make this a satisfactory approach.
Still like to know answers above though!
Terry, East Grinstead, UK
