Adding Frames That I can use the Paintbrush tool on!Help Plz
GIF Animator, SmartSaver Pro, Plugins, Applets....
General_300_200_100
Post by General_300_200_100 »
Hello, im new to this ULEAD gif animator...and ive already started playing with it a little, and its really cool...But ive got something i need help with is...
When i stat ULEAD i first I press File>New then I choose what size and all i want..Then i get a blank white screen...I wanna paint my own things using the Paintbrush but I can only paint on 1 Frame because thats all i got... E.x i paint number "1" using the paintbrush tool on Frame 1, then i wanna paint e.g number "2" but there is no frames... ive tried copy/paste and everything...Please how do I add more frames that I can use the paintbrush tool on...Ive tried rightclicking and then selecting "Add Frame" but when i try to paint on it i get this message "No Active Object For The Operation" = ???
Thanks in advance, The General
bryave
duplicate frames
Post by bryave »
Try using Duplicate frames. Select a blank frame and then press Ctrl+F or right click and then click Duplicate frame. You can then do some painting on that frame. ^_^
†bryave
General_300_200_100
Ok thanks for the reply, but ive already tried that and when i paint lets say a dot on frame 1 the painted dot will appear on all the other frames that ive got...How can i make it so that i the painted things only comes on the frame that im painting on..
Gray
Post by Gray »
General, Go to FRAME and choose ADD FRAME. Then go to OBJECTS and choose NEW BLANK. That will give you a new frame to work on.
Gray.
