Restoring "Edit History"
taan
operating_system: Linux
System_Drive: N/A
Corel programs: ASP 2.3.0.99
Post by taan »
I recently had an issue with my catalog and ended up creating a new catalog and importing the files again.
This pulled in any xmp files and preserved any editing I had done to a file, however I can no longer see a files "edit history".
Is this able to be viewed somehow, so that in certain cases I can revert changes easily?
Taan
lathspell
Re: Restoring "Edit History"
Post by lathspell »
The XMP sidecar file contains only the parameter values for the last edit, so after importing the files and its sidecar parameters into a new catalogue there isn't any history.
taan
System_Drive: N/A
Post by taan »
Thank you lathspell,
Do you know where the edit history is stored?
I may be able to copy the file manually.
lathspell
Post by lathspell »
I can only tell for Windows, where the database files are stored in a "AfterShot Pro Catalogs" subfolder of a user's "My Pictures" folder. But I doubt that you could simply copy these database files for re-gaining access to the edit history ...
