Alternative to ztext for 64 bit 2.2 and up?
AfterShot Pro Plugins
rileyrg
operating_system: Linux
System_Drive: N/A
Post by rileyrg »
I'm looking to watermark some photos. Suggestions on the best way?
Hobgoblin
System_Drive: N/A
Re: Alternative to ztext for 64 bit 2.2 and up?
Post by Hobgoblin »
rileyrg wrote:I'm looking to watermark some photos. Suggestions on the best way?
Go back to AfterShot Pro 2.1.2.10 :cry:
rileyrg
System_Drive: N/A
Post by rileyrg »
I'm kind of getting the impression that this is a bit of a dead in the water development :( Thanks for the advice. I think I'll return to Gimp.
Dutchmm
System_Drive: N/A
motherboard: Asus 97
processor: Intel i7 4785T
Video Card: Onboard Intel
sound_card: Intel AC97
Hard_Drive_Capacity: 2.5TB
Monitor/Display Make & Model: Philips 28"
Corel programs: ASP 3 Pro (and 2 and 1 before)
Post by Dutchmm »
As you are on Linux, you can probably do everything zText gave you with imageMagick. You probably already know that it's possible to incorporate a script into output batches, so you can embed values in the metadata and pick them up in the imageMagick code you apply to your conversions. Feel free to PM me if you want help in exploring this (I only used it to print numbers on photos I was sending to my print processor).
hannes_hab
System_Drive: Z
motherboard: ASUSTeK P8H77-I
processor: Intel Core i7 3770K 3.5 GHz x 8
ram: 16 GB
Video Card: AMD Radeon R7 200 Series
sound_card: Radeon HD 7700 7800 Sapphire
Hard_Drive_Capacity: 2x250GbSSD
Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
Corel programs: AfterShotPro 1, 2, (3)
Post by hannes_hab »
Though hoping that zText, zFrame, zSoften (and others) will be available for ASP 2.2 + I also would be interested to have an alternative method to do what is done with these plugins.
Thank you Dutchmm for the hint with imageMagick and the output batches.
Would be nice to have more information on how to do this with ImageMagic.
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
Dutchmm
System_Drive: N/A
Post by Dutchmm »
Hi Hannes
Sorry for the delay in responding - I should put the plugins forum on RSS, I suppose.
Here is my - not very good - watermarking script to overprint the "DSCxxxxx" name component on all the files in the current directory:
#!/bin/bash
for x in `find . -name \*.jpg`;
do
y=`echo $x | sed -e "s:\.\/::g"` # Extract the left hand end of the filename, because
w=`echo $y | sed -e "s:\.jpg::g"` # we shall need it for the watermark text
z=`identify $y | cut -f3 -d " "` # Get the dimensions for this picture
# Now we have the text to print on the picture (w) and its dimensions (z)
# we can make a transparent picture of the correct size
convert -background transparent -fill black -gravity South -size "${z}" label:$w $w.png
# Daft loop to ensure we shan't continue until linux has finished writing the transparent picture
goon=`lsof -t $w.png`
while [ -n "${goon}" ]
do
wait 10
done
# Now the transparency is ready, we can lay it on top of the original
wait 100
# My printing service doesn't want pictures at more than 250dpi for prints under 20cm by 30
# So resize and write to a JPG with a relevant but non-destructive filename.
convert -units PixelsPerInch $w.png -density 250 $w2
done
Andreas' book (section 9.2) gives some guidance on how to use ImageMagick directly in a custom batch file, in brief using "%1" as the token with which ASP will connect each image to the single ImageMagick command to run. Where you need to script something more complex, the shell script will receive
the output from ASP as $1.
I hope this is some help.
hannes_hab
System_Drive: Z
ram: 16 GB
thank you - tried it - and its working (only get the message: "Zeile 27: wait: Prozess 100 wurde nicht von dieser Shell gestartet.").
I found out how to change color of the text, but not how to change position, size, font ...
Thank you for the Hint with Andreas ASG - I have the book but did not notice the pages concerning ImageMagick.
regards Hannes
austria
tintin
processor: Ryzen R5 3600X
Post by tintin »
hi,
just for your information. I'm currently about to build all the zPlugins for the latest ASP versions.
i will send them very soon to Corel for testing and putting on the plugin page.
br
tintin
my plugins on the official plugins homepage
If you find my plugins helpful, please make a donation to support further developments - just click here, thank you!
hannes_hab
System_Drive: Z
ram: 16 GB
Thank you for the good news!
regards Hannes
austria
twan052
operating_system: Mac
System_Drive: N/A
motherboard: Gigabyte GA-z87x-udh3
processor: Intel Core I7
Video Card: Intel HD4600
Hard_Drive_Capacity: 3TB
Monitor/Display Make & Model: Dell-u2713h
Corel programs: Aftershot Pro
Post by twan052 »
tintin wrote:hi,
br
tintin
Good news makes ASP 2.2 again a little useful for me.
Still use ASP 2.1.10 due to lack of supported plugins
and several bugs first introduced in update versions 2.2.xxx
Thanks in advance,
Twan
timolavi
System_Drive: N/A
Post by timolavi »
I have found Dutchmm's script usefull and made some development in it.
- It removes temporal png-files
- it resizes final jpg-files to horizontal size 749 as default, but size can be changed by first parameter.
- In the second parameter you can give directory and present directory is default.
- it is now case insensitive in file names
- it puts given text as "watermark" at SouthEast corner with font size proportional to horizontal width of the image. Proportion is now 1/30. (c=`expr $b / 30`)
- font must be changed to some installed one, those installed ones can be listed by "convert -list font"
- there is some debugging output of variables
#!/bin/bash
if [[ "$2" != "" ]]; then
directory="$2"
else
directory=.
fi
echo 'directory is '$directory
def_size=749
size=${1:-$def_size}
echo 'size is ' $size
cd $directory
for x in `find . -iname \*.jpg`;
do
w=`echo $y | sed -e "s:\.jpg::gI"` # we shall need it for the watermark text
a=`expr index $z x`
b=`echo $z|awk -F'x' '{print $1}'`
c=`expr $b / 30`
echo $x $y $w $z $a $b $c
convert -background transparent -fill dodgerblue -strokewidth 3 -stroke none -gravity SouthEast -size "${z}" -font Comic-Sans-MS -pointsize $c label:"\@Some text" $w.png
#echo $w2
convert -units PixelsPerInch $w.png -resize $size'x' $w2
done
timolavi
