Apply auto transition effect
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
I have a project with over 300 jpeg images in it .I want to have a cross fade transition in between each one .In preferences, under the edit tab I have , in the edit tab, under transition effect, ticked auto add transmission effect .In the default transmission field, I have selected FX cross fade. But this has not achieved want I want(or anything at all). What I am doing wrong
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: Apply auto transition effect
Post by RobertOZ »
What you have done is correct, does your Edit screen look like this
Ken Veal
ram: 32 GB
Post by Ken Veal »
Yes, looks the same apart from duration and PAL
RobertOZ
Post by RobertOZ »
PAL makes no difference with images so it should work for you, what duration have you set for transitions and what duration do you have for your images
canuck
operating_system: Windows 8.1
Post by canuck »
Ken Veal wrote:I have a project with over 300 jpeg images in it .I want to have a cross fade transition in between each one .In preferences, under the edit tab I have , in the edit tab, under transition effect, ticked auto add transmission effect .In the default transmission field, I have selected FX cross fade. But this has not achieved want I want(or anything at all). What I am doing wrong
Did you add the images before you set the default transition? If yes, then setting the default transition have no effect. The transitions has to be set before you add the images
Ken Veal
ram: 32 GB
Post by Ken Veal »
I think having the images in the timeline before setting the default transmission is the problem.If I add more images, the cross fade transmission is added automatically though.So, is the answer to drag back all the timeline images into the sub folder , then delete them in the timeline and them drag them all back into the timeline ?
Post by BrianCee »
Yes that is the way to do it Ken - the choice needs to be made before any images are put in the time line - then it will work
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
I'm glad to teach you guys the proper way...
VS has the tool for that , no need to redo Ken,
First, right click on the left side of your track to select all media
than select the crossfade and apply to that track.
Panasonic X900m, VXF1
no need to select all media
simply select a transition and apply current effect...., either the top icon, or right click transition clip for "apply current effect......"
