Appalled by DVD Pictureshow 3
tommy139
Post by tommy139 »
I bought Ulead DVD Pictureshow 3 Deluxe two days ago, installed it then downloaded and installed the available update patch.
Since then, I have tried many times to make a slide show and burn it to DVD, these range in size from 8 slideshows with approx 50 pictures each, down to a single slideshow with just 10 pictures.
The only slideshow I have been successful with is the smallest, and I only made one this small to test if the program would actually work at all.
The program has crashed on every other project, and before it crashed it was so incredibly slow.
To say I am dissappointed would be an understatement.
The machine it is running on is not an ancient one either, 80gb HD with over 45gb free, 2400 AMD Athlon with 512 mb ram so I dont think the hardware can be the cause.
I think I am calling PC World tomorrow to see what their returns policy is.
pwllderi
Post by pwllderi »
I have wasted all day Wednesday 5th, and so far I have achieved 'crashes' and 'temper tantrums'.
What a waste of money!!
Rob T.
Post by Rob T. »
Ditto . . . I sure wish I knew about this forum & read all the compliants beforehand, I certianly would not of purchased this product. I'm totally frustrated with it.
Rick F
Post by Rick F »
:D Hi all I too purchased PS3 and had crashes while burning discs , and had the oportunity to read all the posts regarding the failure of PS3 for the last 2 months, and even sent my complaint to U-Lead teckies . I do believe they need to look their program over and fix it so it will burn to disc without crashing. It is a very good program otherwise and very creative I believe. However not being one to give up easily , one post I read , Solved part of my problem , It suggested to burn to a DVD-RW disc and especially "FORMAT THE DISK" is important, which I did not know? I was succesful in completing the burn without a "freeze" I then used Nero 6.1 to copy that disc to a DVD+R , it played great with music, transistions etc ( a 58 slide show) on my computer , my wifes computer and my standalone DVD player and TV. :D Give it a try it may work for you . Oh yes , when I first logged on I temporarily turned off all the programs running in the tool bar including Norton. The burn took about 10 minutes at 4X on my Sony 700 UL exterior burner . Good luck [/u]
Rick Fredrickson from Northern California
tommy139
Post by tommy139 »
Rick F wrote:However not being one to give up easily , one post I read , Solved part of my problem , It suggested to burn to a DVD-RW disc and especially "FORMAT THE DISK" is important, which I did not know? I was succesful in completing the burn without a "freeze"
The problems I have been having are that the program has been crashing while building the slideshows, it never gets to the burning the DVD stage !!!
tommy139
Post by tommy139 »
I called the shop where I bought this product today, PC World in Manchester, to ask about returning this for a refund. They confirmed what I already expected, that they will not allow this item to be returned unless the actual CD is physically faulty, and then it would only be for an exchange and not a refund.
So, unless Ulead themselves are going to be helpful about this with either a refund or an actual product that works, it looks like I have bought myself two more CD's that can only be used as table mats for drinks.
COME ON ULEAD - SORT IT OUT !!!
unsaman
Post by unsaman »
I am having the same problems with burning either into a DVD or image file.
It consistently freezes when rendering/processing slideshow #3.
I have emailed ULEAD 2 days ago but have not gotten a response yet.
As mentioned on an earlier post, the trial version works flawlessly.
I was able to burn my picture & video slideshow with no problems.
So it turns out the trial is better than the full version.
Has anyone heard from ULEAD about these problems?
Has anyone tried to get a refund of this product if purchased via ULEAD mall download?
dunwitu
Exact same problem
Post by dunwitu »
I've emailed thier tech support two weeks ago and still no response. I really debated between this and proshow gold, boy did I make a mistake.
pwllderi
Post by pwllderi »
Tech support was advertised as closed until 5th January
Notice the size of the slideshows - in version 3 they are huge [3gb] the same project in version 2 [0.3gb]
This is the problem with me, the work is 10 times bigger on v3, so you can only fit on the DVD 1/10 of what I can with version 2!!!!!!!!!!!!!!!!!!!!!!!!!!
I have reverted to using version 2 now!
angrakiller
Post by angrakiller »
My situation is that when I try to burn into a DVD+RW, an error message will pop up in the converting process, after several unsuccessful attemps then I check the "Format DVD+RW" option on the output options dialog box, this time it works.
But when I try to burn into a DVD-R disc, the error will pop up in the writing-to-disc process.
I have filled the support form and hope ULEAD can find out the cause and release a patch for this problem.
By the way, if you have installed 16X DVD Burning Pack, you can uninstall it, they told me so far DPS3 has problem with this pack, they will release a new pack instead...
hokan
Don't hold your breath for technical support.
Post by hokan »
I've been working with these guys for 3 weeks. As I mentioned in other posts the support has been terrible. Here is today's reply. My problem is crashes during the disc imaging stage among others.
Sorry for the inconvenience. The described scenario is not normal. There should be no problems using the software on Windows XP as long as the system requirements are met. Based on experience, these types of problems can be solved by uninstalling and then reinstalling your software. Please make sure to logon as Administrator before installing your software to avoid restrictions. And it is also recommended that you restart your computer after every installation. You can also try installing the software on another computer and if it works normally then this proves that there is nothing wrong with your software. The problem may be caused by computer is already unstable or some other programs are causing conflicts andrestrictions within your system.
> Best regards,
> -Rodel Villasenor,"
This is the very same cookbook answer I was given 3 weeks ago. I guess they just work thru the cook book and then it is back to the begining recipe. BTW, apparently if the program will work on one computer then its good. I guess everyone here has an unstable computer...it really shortens development time if you only need to get the software to work on a single computer system.
ahk123
Glad I read this.......
Post by ahk123 »
I was going to purchase this program...........am I glad I happened to join this Board and read all the comments.
Hope it all works out for you guys.
Annette :roll:
angrakiller
As my understanding, those customer support agents really can’t do much to solve bugs, what they can do is report to the programming department and wait for solution or a patch.
After all they are not programmer, and they all work under the pressure of users’ anxiety and anger.
tommy139
Post by tommy139 »
angrakiller wrote:As my understanding, those customer support agents really can’t do much to solve bugs, what they can do is report to the programming department and wait for solution or a patch.
The customer support agents are in a difficult position and I think every here who is complaining are aware that they can only say what they are told to say.
The real culprit is ULEAD who have put out a piece of software riddled with bugs.
pwllderi
Post by pwllderi »
Is there any way to set a default slideshow setting?
In a project of ten slideshows I have to change each slideshow for transition, font, position of font, and no music.
Where is the ability to have your personal default?
