SJS wrote:OK, here is an example: I have an image that I want to separate into multiple layers to manipulate. So I want to select a section and promote it to a layer, but it is easiest to select the "background" area of the image, which may be my almost white scanner cover:-). So I magic wand select that, to invert the selection & promote it to a new layer.
At that point the specks & flaws that I failed to notice to "modify/remove holes" may show up, OR I may not notice until I have made some changes and increased the zoom a few steps later. Now I want to back up & get a cleaner selection, so I "undo" the steps since selecting the background. In History the "undo" shows as OK, but if now I promote the selection, it is NOT the "white" background that gets promoted: the "undo" works for everything except "invert selection.
I am using X9, Windows 10, and working with 300 - 400 dpi images. I see this with various size files.
Following your steps I I think I see what you're saying. I start with a blank History palette. Then it shows Magic Wand, Invert Selection, Promote Selection, Select None (so I can start working on the new layer), and Clone tool several times (which I used to make a few changes to the promoted selection). Now I use Undo and watch it step back through all of the Clone stuff, undoes Select None so I have the selection back on the promoted selection), then undoes the promoted layer so I'm back to a Background layer with the object still selected. Hit Undo again and the Invert Selection in the History Palette looks like it's undone but the selection is still around the object. Hit undo again and the Magic Wand is now undone and there is no selection whatsoever. So yes, it doesn't undo the Invert Selection.
However, I now have a History palette with all of those steps undone. If I now hit the Redo button the palette shows the Magic Wand active again and also the original Magic Wand selection of the white background is back on the image allowing me to clean up the missed stuff. Then I either have to use the History palette to re-do the Invert Selection or, preferably, just do Invert Selection and start fresh by then promoting the object, etc.
