Optimising for YouTube uploads/file size
MikesMovies
motherboard: Gigabyte Technology Co ltd H81M-DS2V SOCKET 0
processor: Intel Core i5 4460
Video Card: NVIDIA GeForce GTX 1050
sound_card: NVIDIA Virtual Audio Device
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: PHL 242B1
Corel programs: Video studio X10 and PaintShop Pr
Post by MikesMovies »
Hi everyone
Ref: https://support.google.com/youtube/answer/1722171?hl=en
I have been looking at Studio X8s settings trying to get as close to what YouTube recommended as possible.
I have settled on a bit rate of 10000 which is 2k higher then the min the ask for and produces nice file sizes at my current work rate.
Using the MP4 container I can't get the audio bitrate wanted 384kbps, best I can get is 256?
Under video codec:H264 I can't find anything other than the 'high profile' setting.
Has anyone managed to find a custom setting that gets as close as possible to YouTube's request?
Thanks.
Kind regards from Mike in Sussex UK
https://www.youtube.com/user/mikesndbs
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Re: Optimising for YouTube uploads/file size
Post by rguthrie »
Mike, check out my tutorial on installing the Xvid codec: 09: VS 11/11.5: Encoding in Xvid MPEG-4. It's a bit dated, but should still be valid. If you have any questions, let me know and I'll help as much as I can.
SFC (Retired) Ronald Guthrie (aka Alt0S4x)
VS4SE/6-11.5+/X2-X10 Ultimate/2018-2023, Pinnacle Studio 25; Ultimate; MotionStudio 3D; PI11/PIX3;Corel PainterEssentials 4
Photoshop CS5; Audacity; SonicFire Pro 6.0
Wacom Bamboo Fun Tablet
Canon Rebel T4i
MikesMovies
rguthrie wrote:Mike, check out my tutorial on installing the Xvid codec: 09: VS 11/11.5: Encoding in Xvid MPEG-4. It's a bit dated, but should still be valid. If you have any questions, let me know and I'll help as much as I can.
Hi there, many thanks.
I followed it as closely as I could allowing for the updates within the xvid pack and VS X8 that I am using.
Profile manager etc.
I could not set the audio as described, so left it PCM.
Sadly nothing can play the outputted file?
Here is a mediainfo report.
General
Complete name : C:\Users\Mike & Cheryl\Desktop\xvid test.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 5.74 MiB
Duration : 30s 764ms
Overall bit rate : 1 565 Kbps
Video
Format : MPEG-4 Visual
Codec ID : XVID
Codec ID/Hint : XviD
Bit rate : 1 bps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.000
Stream size : 2.00 Bytes (0%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 30s 733ms
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 5.63 MiB (98%)
Alignment : Aligned on interleaves
Interleave, duration : 33 ms (1.00 video frame)
MikesMovies
This video shows the settings I have.
https://youtu.be/20Jn1XyFpOk
Maybe you can spot where I have gone wrong?
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
MikesMovies wrote:Hi everyone
Thanks.
Why do you care if it's 256 and not 384? is your project is of classical music symphonic nature?
Panasonic X900m, VXF1
MikesMovies
Thanks.
This topic is about optimising for YouTube, 384 is what they ask for, personally 128 would be fine for most of my stuff.
Post by BrianCee »
Sorry Mike but 384 is not what they ask for - it is what they RECOMMEND - by all means get as close as possible but you do seem to be worrying about a recommendation - it is not an order, they will still accept your video with 256.
MikesMovies
Ok here are two uploaded videos for you to look at, after all it is how YouTube treats it that matters.
https://youtu.be/oMtWajU1mWo
MPEG Transport-Stream Files
24 bits, 1920 x 1080, 29.97 fps
Frame-based
(HDMV-NTSC), 16:9
H.264 Video
Video data rate: Variable (Max. 12000 kbps)
Audio data rate: 384 kbps
2 passes.
This produced a 44.6mb file that was available on YouTube in double quick time.
The second upload
https://youtu.be/8zYLVvhvel4
Was done using my normal output files settings.
MPEG-4 Files
Frame-based
H.264 High Profile Video: 15000 Kbps
48000 Hz, 16 Bit, Stereo
MPEG AAC Audio: 192 Kbps
Upload was a little slower but so was processing after.
Looking at each file on the screen here direct (not on youtube) we were not able to see much difference between them.
Full media file info is included in the video description boxes.
I'd be most grateful for your observations?
Post by BrianCee »
Studied them both in detail on my screen Mike - even had them both playing simultaneously while I switched back and forth between them
both excellent quality and both 100% acceptable - very little difference between them although my impression was that the mp4 was very marginally crisper.
MikesMovies
BrianCee wrote:Studied them both in detail on my screen Mike - even had them both playing simultaneously while I switched back and forth between them
:D Thanks Brian! most helpful, I am left wondering if I used say 9000 as a max bit rate (1k above YouTubes suggested) how that would look?
MikesMovies
Instead of wondering here it is
https://youtu.be/Thkgyut78eo
30.5 mb file size, would it be interesting to check 'same as project' and upload best quality?
MikesMovies
https://youtu.be/d1KKQynSBRo
Here is the 'same as input' output 80.3mb
Post by BrianCee »
Well I couldn't find any fault with either of those last two either Mike - I've played them while carefully studying the spokes on the moving wheels and I cannot see any difference.
MikesMovies
BrianCee wrote:Well I couldn't find any fault with either of those last two either Mike - I've played them while carefully studying the spokes on the moving wheels and I cannot see any difference.
Hi Brian
Interesting isn't it!
In fact the one conclusion I have come to is YouTube's output is poor compared to the actual files.
Even looking at the 9K file I can read more numbers on the wagons in the background than I can on any of the YouTube videos.
This kind of suggests it's not worth uploading massive high quality files to them, only for them to present video around the 8K mark?
Bit disappointing really.
MikesMovies
Hi Brian and all
So from all this I think I have worked out a compromise settings.
The output file will be made like this (version of the online preset)
What would your thoughts be?
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 34.6 MiB
Duration : 31s 31ms
Overall bit rate mode : Variable
Overall bit rate : 9 357 Kbps
Encoded date : UTC 2015-11-03 16:59:00
Tagged date : UTC 2015-11-03 16:59:00
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 31s 31ms
Bit rate mode : Variable
Bit rate : 9 160 Kbps
Maximum bit rate : 10 000 Kbps
Frame rate mode : Constant
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.147
Stream size : 33.9 MiB (98%)
Language : English
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 30s 999ms
Bit rate : 192 Kbps
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Stream size : 727 KiB (2%)
Language : English
