Messed up my PSP install so can't reinstall X3 or X8 trial
Tomssoft
motherboard: nanana
processor: nanana
ram: 12gb
Video Card: nanana
sound_card: nanana
Hard_Drive_Capacity: nanana
Monitor/Display Make & Model: nanana
Corel programs: paintshop pro
Post by Tomssoft »
I moved my X3 ultimate installation (bought from corel) during an upgrade to Windows 10 (I had run out of space on C main system drive, so I moved everything out)
Now I can't reinstall 3x
I have been through regedit searching for everything ulead and corel removing it.
(Is there any guids I need to search for?)
I figured hat was okay, and I could by X8, but I can't even install the trial (X8 standard)
It errors a 31% with a messagebox stating
"Error"
"We encountered a problem while installing."
And that's how much progress I made :(
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Re: Messed up my PSP install so can't reinstall X3 or X8 tri
Post by trueblue »
Tomssoft wrote:I moved my X3 ultimate installation (bought from corel) during an upgrade to Windows 10 (I had run out of space on C main system drive, so I moved everything out)
"Error"
What do you mean by 'moved out'? If you have insufficient system drive then yes, you are going to run into trouble. You need a bigger hard drive to accommodate the operating system and also programmes.
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
Tomssoft
motherboard: nanana
processor: nanana
ram: 12gb
Video Card: nanana
sound_card: nanana
Post by Tomssoft »
I moved my PSP installation to another disk/partition. It is merely my system drive/partition that was running low at the time. Currently my system drive is 120gb with 90gb used by Windows and Microsoft software.
Overall i have well above on 1TB so space as such it not an issue :)
Tomssoft
motherboard: nanana
processor: nanana
ram: 12gb
Video Card: nanana
sound_card: nanana
Post by Tomssoft »
If anyone has experience solving the problem with the error message or who I can contact - please write. I would like to buy X8 if I can get it working
I am wondering if moving my X3 installation to another disk somehow triggered something hanging left? Could e.g. be
- MSI installation - but why does that affect X8?
- Anti piracy measure going haywire after moving X3?
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
I am assuming that by "moving" you mean that you uninstalled PSP from your system disc and then did a regular installation of the program to another drive. Is that correct? If so, did you use the uninstall tool provided in the sticky topic near the top of this forum to do a clean uninstall? If not, I suggest that you download the tool and use it to uninstall PSP, then try installing again on the drive of your choice. You likely have to temporarily disable your anti-virus to run the uninstall utility because it removes PSP remnants from the registry and anti-virus often stops programs from doing this, because that is also something that some virus programs try to do.
JoeB
Using PSP 2019 64bit
Tomssoft
motherboard: nanana
processor: nanana
ram: 12gb
Video Card: nanana
sound_card: nanana
Post by Tomssoft »
Well, there is no clean utility for X3, only for X4 and upwards
Truth to be told, I think I simply tried moving it hoping X3 would work. That was naive, but at the time I had focus on getting Win10 working. That said, I had not imagined that i would not manually be able to fix the issue (searching the registry and removing values manually and/or using revo)
JoeB
ram: 8 GB
Post by JoeB »
Tomssoft wrote:Well, there is no clean utility for X3, only for X4 and upwards
In 99% of cases you can't simply move a program that has an install feature to install it, only programs that don't need installation. That's because during installation the install program writes information to the system (including the registry) telling it where the program and various other features of the program are located and how those locations are to react to system commands that the user inputs and that the program calls while in use.
So you'll have to uninstall whatever you've installed and start again with a proper installation. Somebody else will be able to tell you if and where you can locate a clean uninstall utility. I don't have X3.
JoeB
Tomssoft
motherboard: nanana
processor: nanana
ram: 12gb
Video Card: nanana
sound_card: nanana
Post by Tomssoft »
Currently neither installer nor uninstaller will run for x3 / x8 whatever
If anyone knows of x3 cleaner please point me to it!
I have already tried clean what I could find by searching regedit for corel, ulead, paintshop - I will try some more searches later
Still puzzles me why x8 installer won't run - could not imagine that would be influenced by x3 :)
If anyone knows where I can see x8 install log (if any) please point me to it.
JoeB
ram: 8 GB
Post by JoeB »
Corel should be able to answer those questions for you.
JoeB
Tomssoft
motherboard: nanana
processor: nanana
ram: 12gb
Video Card: nanana
sound_card: nanana
Post by Tomssoft »
i got no reply from corel, but no matter. I solved it
1)
make sure u try stop and remove protexis services in Windows services control (e.g. sc delete Protexislicensing)
2)
in regedit delete everything (your own responsibility etc.) with regards to
paintshop
protexis
ulead
corel
3)
Then search google for removing protexis and make sure the file are gone
4)
reboot the machine (this really is necessary)
I am now a registered owner of x8
