crop menu bar has disappeared
ericdrandall
- Corel programs: Paintshop Pro
Can anyone tell me how to restore the crop menu bar, which has disappeared? The elements are Presets, check mark, width/height/units, etc. thanks in advance
LindaSue
- motherboard: Gigabyte
- processor: 2.71GHz AMD Athlon II X2 215 processor
- ram: 3 GB
- sound_card: Realtek AC97 Audio [onboard]
- Hard_Drive_Capacity: 1320 GB
- Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
- Corel programs: Paint Shop Pro X2, X4, X6
Re: crop menu bar has disappeared
Go to File > Preferences > General Program Preferences > Transparency and Shading. Tick the box "Enable Floating Crop Toolbar"
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
Go to View/Palettes and click on Tool Options. Hot key is F4, can also access with right click.
Mark
ericdrandall
Thanks, but neither of the two suggestions worked for me in PSPro8. Instead, I did File/Preferences/Reset Preferences and checked Reset Workspace to Default Configuration. that worked. ....But I would not have found it if not for the help!
LindaSue
- ram: 3 GB
You didn't mention which version of PSP you were using so I assumed it was a recent one. You also didn't mention that you weren't seeing the tool options bar for any of your tools. You only mentioned the Crop tool specifically. PSP8 doesn't have the floating crop bar that I mentioned. I'm glad that you fixed the problem.
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
the details in your profile info (which show at the right of your posts) only say that you use Paint shop Pro, but not which version. You should edit your profile with the specific version so that people responding to your questions know what version you are using.ericdrandall wrote:Thanks, but neither of the two suggestions worked for me in PSPro8. Instead, I did File/Preferences/Reset Preferences and checked Reset Workspace to Default Configuration. that worked. ....But I would not have found it if not for the help!
JoeB
Using PSP 2019 64bit
JoeB
