Safe to UNINSTALL X7 if you have X8?
vpnavy
Post by vpnavy »
Just cleaning up and noticed I still have X7 installed but using X8 now. Is it safe to UNINSTALL X7?
Thanks!
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: Safe to UNINSTALL X7 if you have X8?
Post by JoeB »
vpnavy wrote:Just cleaning up and noticed I still have X7 installed but using X8 now. Is it safe to UNINSTALL X7?
Thanks!
Yes, if you are sure that there are no resources in the X7 install folders that you have added there and might want to keep for use with X8. However, there really is no reason to uninstall X7 unless you want to because all versions of PSP (including the Jasc versions) coexist well together. You might want to search the forum to see if any bugs showed up in X8 that might affect your workflow in case you need X7 for use in those cases.
JoeB
Using PSP 2019 64bit
vpnavy
Post by vpnavy »
JoeB wrote:Yes, if you are sure that there are no resources in the X7 install folders that you have added there and might want to keep for use with X8...
Thanks JoeB.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Things that would be kept in X7 folders are gradients that you made while using X7. Or Scripts. Or textures, patterns, saved selections, masks, displacement maps, brushes, picture tubes, all of those specialty items that you yourself made and exported.
Those would exist in your X7 folders.
C:\Users\username\documents\Corel PaintShop Pro\17.0\
If you made anything like that you can copy your X7 folders over to X8 and X8 will pick them right up.
C:\Users\username\documents\Corel PaintShop Pro\18.0\
vpnavy
Post by vpnavy »
LeviFiction wrote:Things that would be kept in X7 folders are gradients that you made while using X7. Or Scripts. Or textures, patterns, saved selections, masks, displacement maps, brushes, picture tubes, all of those specialty items that you yourself made and exported...
Super - I have never saved anything, etc. - just modified existing images with menu features. Thanks!
