For some reason, I've always had trouble uploading videos directly to Youtube from VSX6. I don't know why, but whenever I select Youtube to upload to, it doesn't recognize my username or password. I know that I'm entering it correctly. I signed into YT with no problem. In fact I never have problems signing into YT. However, I have never been successful signing into YT from VSX6.
I really want to get this solved once and for all. It's very inconvenient. I Selected YT to upload to and waited about half an hour for it to upload just to find out I couldn't sign in so all the trouble uploading was a waste of time because it didn't work. i really like VS but if I can't solve this, I'm going to start looking for another program that works. This is one of so many issues I've had with VS.
Trouble uploading to Youtube
rkstudio
- motherboard: There is no motherboard listed
- processor: Intel Core i7-855ou CPU 1.80 GHZ
- Video Card: Radeon 540 Graphics
- Hard_Drive_Capacity: 256 SSD
- Monitor/Display Make & Model: Radeon 540 Graphics
- Corel programs: Videostudio 2020 Pro
Re: Trouble uploading to Youtube
I found that the problem is that if you have a Google account any where on your computer then Videostudio insists on trying to sign in to Youtube using that Google account
The solution for me was simple - and I think better. I just create my video in Videostudio - exit VS - check out the quality and content of the video - sign in to Youtube and upload the video where I can see every thing happening - end of problems
donsmi
This week I started having upload problems. I get about half way and get a window that says can't upload check internet connection. I use wi fi and had it checked out the signal strength.
Any help would be appreciated.
You may be best to connect to YouTube from your Internet Browser instead of through Video Studio.
Do you have similar problems in doing that?
As Brain says it’s a better option as you can play the video to check quality before uploading to YT.
donsmi
Hate to sound like a dummy, but how do you upload to youtube, all I see is my other videos that have been uploaded.
You sign into your account on Youtube
and click the 'Upload' button - then follow the prompt
Are you saying you have never uploaded to your Youtube account?
From the YouTube home page to the top right I see my icon and an "upload" link
selecting that will prompt me to "Select files for upload"
donsmi
Thanks got it going thru YouTube. The only thing had to use Windows Video Maker, the Corel used a different need to figure out how to format so I can use Corel.
Thanks again.
Thanks again.
X6 YouTube template uses these settings
MPEG-4 Files
24 bits, 1280 x 720, 25 fps
Frame-based
H.264 Main Profile Video: 5000 Kbps
44100 Hz, 16 Bit, Stereo
MPEG AAC Audio: 128 Kbps
You can view these after choosing Upload to YouTube – Mpeg4 16:9 HD in the lower properties panel.
From Share Create Video File – Mpeg4 - MPEG-4 AVC (1280x720)
Uses the same settings as above allowing you to render the project to same video type.
Also
Using Settings Make Movie Templates manager allows you to modify / create your own template
Increasing the data rate should improve quality but also increase file size.
MPEG-4 Files
Frame-based
H.264 High Profile Video: 9000 Kbps
As you are in the USA your template will use 29.97 fps not 25fps as in UK.
Hope this helps
MPEG-4 Files
Frame-based
Also
MPEG-4 Files
Frame-based
Hope this helps
