Just another bug I have discovered in the latest update, ASP 2.2.2; When trying to enter a numeric value in the box at the right side of the sliders, the setting is reset to 0,00 the moment I hit enter. It seems to do that for all sliders/adjustment values. I don't think I have experienced this bug in the previous versions...
As it is now, I have to rely only on the values I get from adjusting the sliders. For some settings the given value range is too coarse. Hope Corel can fix this bug resonably quickly...
(PS! My system info is stated in my profile...)
[ASP 2.2.2] Ajustment panels - Numeric value resets to zero
Arnfinn
- motherboard: ASUSTeK Computer INC. SABERTOOTH X58 Rev 1.xx
- processor: Intel Core i7 CPU 960 3.20GHz 3.20GHz
- ram: 12 GB
- Video Card: NVIDIA GeForce GTX 670
- sound_card: High Definition Audio Device [5x]
- Hard_Drive_Capacity: 12 TB
- Monitor/Display Make & Model: BenQ G2400W 24,0" + Acer X203H 19,9"
- Corel programs: ASP
Long time AfterShot Pro & Bibble user...
http://creativewithlight.com/
lathspell
Re: [ASP 2.2.2] Ajustment panels - Numeric value resets to z
Probably a non-fixed localization bug, please see here:
http://forum.corel.com/EN/viewtopic.php?f=94&t=57150
Give a try to use "," instead of "." as decimal separator or vice versa.
(The decimal separator on the numpad is typically bound to "." or "," depending on the localization of the operating system. I remember that in the early days of MS-DOS and Windows this was a PITA and there were little programs just for the purpose of re-asigning the numpad separator ...
Arnfinn
- ram: 12 GB
Well, it seems like it isn't related to either a comma (,) or a period (.). If, for example, I adjust the "Straighten" slider and get the numeric value of 3,79. When I click in the numeric box I can place the cursor anywhere between the numbers without any problem, but the moment I use the delete or insert button to remove a number or the comma, it resets to zero in an instant. If I mark and delete the given value and apply another number, with or without a comma or period separator it resets to zero. Any attempted changes to the number resets it momentarily to zero.
The only thing I can do (that doesn't reset the value to zero) is to use the graphical slider. Everything else resets the value to zero...
lathspell
Oops, sorry, my mistake. I didn't get the actual problem. Hm, so that's one bug more to fix ...
