Center guides?
mjrielly
Center guides?
Post by mjrielly »
Is there a way to automatically center the vertical and horizontal guides?
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Center guides?
Post by LeviFiction »
I do not believe there is any shortcut key or setting that allows you to snap a guide to a certain place. But you can use scripts to create guides according to very simple rules.
There are already two scripts that add guides inside of PSP. Guides - Rule of Thirds and Guides - Golden Rule.
Obviously these are not what you want but they show it can be done.
I am uploading a script that will automatically set two guides directly in the center of the image both horizontally and vertically. The forums don't allow us to upload the scripts directly so I've placed it inside a zip folder.
To use it, open the zip folder and copy the PSPScript file into your scripts-restricted folder.
If you don't know where your scripts-restricted folder is you can find it inside of PSP by going to File -> Preferences -> File locations.
Select "Scripts-restricted" from the list on the left. And on the right you'll see a list of folders where PSP looks for restricted scripts.
Guides - Quarters.zip
(691 Bytes) Downloaded 154 times
mjrielly
Re: Center guides?
Post by mjrielly »
Awesome! Thank you!
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: Center guides?
Post by JoeB »
LeviFiction wrote:I do not believe there is any shortcut key or setting that allows you to snap a guide to a certain place. But you can use scripts to create guides according to very simple rules.
Could I suggest that you post this script in the Scripting sub-forum?
JoeB
Using PSP 2019 64bit
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Re: Center guides?
Post by LindaSue »
LeviFiction, would it be possible to edit the script so that it will run in PSP8? I use your "PasteAndMover" script all the time and this one would be handy too.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
ram: 6 GB
Re: Center guides?
I don't recall a paste and mover script.
I just adapted it from Corel's own Guides - Golden Rule script which has a default host of version 9.
To work in older versions the script would have to be edited to use JascUtils and JascApp instead of PSPUtils and PSPApp.
The default host number would have to be changed from 9 to 8 in all commands. And change all instances of "True" to 1 and "False" to 0.
I submitted an updated version with all of these changes into the PSP Scripting forum.
LindaSue
ram: 3 GB
Re: Center guides?
Post by LindaSue »
You created the Paste & Mover script for me a long time ago. It auto pastes as a new layer then activates the Move tool. The actual purpose of the script was to prevent PSP8 from linking layers which is a bug in PSP8 that appears at random when new layers are pasted into an image.
I just tested your updated "Guides - Quarters.PspScript" in PSP8 and PSP9. It works as intended in PSP9 but not in PSP8. It works now in PSP8 but I have to manually turn on the guides either before or after running the script. The script doesn't turn them on like it does in PSP9 and later versions.
JoeB
ram: 8 GB
Re: Center guides?
Post by JoeB »
LindaSue wrote:You created the Paste & Mover script for me a long time ago. It auto pastes as a new layer then activates the Move tool.
The Paste & Move script was actually written by Gary Barton in 2003. There is a link to his Pixelnook script site in the first sticky post in the Scripting sub-forum, which has links to various scripting resources. The direct link to Pixelnook is here:
http://pixelnook.home.comcast.net/~pixelnook/
Paste & Move is bound to a toolbar in my PSP and used all the time - a very useful script. Another favorite but used much less often is Barton's Pause Script, which can be added to scripts to allow you to pause the script at various steps to do something that is difficult or impossible to achieve within a script and then run the main script again.
JoeB
LindaSue
ram: 3 GB
Re: Center guides?
Post by LindaSue »
Well, I don't know where LeviFiction originally got the basic script but he added this bit of code to it to prevent PSP8 from linking the layers:
Code: Select all
    App.Do( Environment, 'LayerProperties',{'General':{'LinkSet':0},'GeneralSettings':{'ExecutionMode':App.Constants.ExecutionMode.Silent}})
