help please, alpha channel doesnt work
Re: help please, alpha channel doesnt work
The question of Boris 6.1 and 6.6 has been discussed in detail here before: http://forum.corel.com/EN/viewtopic.php ... 08#p301808 It is worth reading that thread in its entirety as it suggests several possible solutions. While 6.1 comes as part of the Ultimate package, Boris themselves offer a free upgrade to the plug-in on their website, though they specify that it is for VS X7 rather than X8. Some people who already had X7 found that 6.6 was only installed on X7, but all they had to do was copy the plug-in from X7 to X8 and it worked.
One other thing to try is to go to C:\Users\[Username]\AppData\Roaming\UleadSystems\Corel VideoStudio Pro [x64] and change the name of the 18.0 folder to 18.0_OLD. Then restart X8 and things should be rebuilt, and Graffiti should properly show under FX...
I am unable to replicate monjanse's more specific problem, however. I just created a quick project by using sample video from the VS library. I then dragged Graffiti onto the clip and chose a preset effect at random (in this case ShatterGlow as it sounded like the effect monjanse was trying to achieve.) It appeared to work just fine in preview, with the title exploding and glowing with full alpha channel transparency over the background clip. I then rendered it to a full HD mp4 (h.264, 1920 x 1080, Frame Based, 15 Mbps bitrate). Rendering was pretty quick, and the new clip played back perfectly, again with full alpha transparency of the exploding title over the background clip.
Having looked at monjanse's video on YouTube, however, I am wondering if he has been using Graffiti correctly. It appears he has created a separate title clip, apparently using Graffiti, and inserted it in an overlay track. Graffiti, of course, can be dragged and dropped directly on the main track, and Customised there, changing the text of the title, and having automatic alpha channel transparency. However, if a separate title clip is created and inserted into an overlay track, you then have to go into Options and click on 'Mask & Chroma Key', then tick 'Apply Overlay Options' and customise transparency from there.
Monjanse sent me a private message saying the following in response to my post above:
ok. in gribbs tutorial on page turn, and his tutorial on the boris graffiti 2d particle, it is alpha and added graffiti on the overlay track. the underlying track was showing underneath the overlay tracks pageturn.
I have never seen the Gripps tutorials, so cannot comment on this. In particular, I don't understand what 'page turn' means in this context except in relation to a transition...
I can only repeat that for me, Boris works if applied directly to the video in the main track. It is, after all, a filter in this sense. If applied to a clip which is then put in an overlay track, then that overlay clip IMHO would need to be adjusted using Mask & Overlay to get any possible transparency. But please correct me if I'm wrong or misunderstanding the entire situation.
As a footnote I would add that, as I already told monjanse, we don't reply via private message to substantive questions or comments relating to them sent to us by private message or email. We urge users to post substantive questions and comments on the Board so that others can comment on or benefit from the answers. In this case, I think it is important for others to see monjanse's comment because they may understand it better than I do... :oops:
Hi Ken
If you notice the image provided by Monjanse that the FX library thumbnail for Graffiti also displays as black.
Then simply adding the FX filter to a video clip also turns that black and I assume that’s before customising the effect?
Thanks for the 6.6 version info, I will have to remember in future?????
Monjanse
I am fast running out of ideas but have you checked your Graphics Driver to see if the correct one Is installed. Maybe view the G-Force web site
monjanse
processor: amd ryzen 1700x
ram: 32 gb
Video Card: nvidia gforce 1070 4gb
Hard_Drive_Capacity: 445 gb
Monitor/Display Make & Model: aoc freesync
Corel programs: corel videostudio ultimate 2018
Post by monjanse »
I had to reinstall windows to fix it. But the alphachannel still doesnt work from graffiti to videostudio.
monjanse
ram: 32 gb
Post by monjanse »
Ok. I didnt know graffiti only works on main track. I though sense it was alpha on graffiti it would be alpha in videostudio also.
Hi Guys
I don’t seem to be having any problems applying graffiti to the overlay track
Not that I am an expert in using the plug-in, but it does seem to work.
Monjanse
Can you apply graffiti to one of the library samples.
Then save the project, zip the vsp and attach to your post, we can try your edits with our programs.
monjanse
ram: 32 gb
Post by monjanse »
ok here is the zip file:
test.zip
(2.94 KiB) Downloaded 132 times
monjanse
ram: 32 gb
Post by monjanse »
now i added the zip file
monjanse
ram: 32 gb
Post by monjanse »
and when i adding chroma cey pro to the video, and placing a pictrure behind clip, the picture doesnt show in the green screen chromakeyed video. but it does show when using the built in chroma key in the videostudio.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
The forum is slowwwwwwww here today
Monj, one thing at a time. We still did not understand what you need to do.
1) what grippss video you try to replicate? I want to see.
2) Are you trying to use chroma key AND boris ? show us your attribute screen
3)Do you want to do something like that?
Panasonic X900m, VXF1
monjanse
ram: 32 gb
Post by monjanse »
ok
monjanse
ram: 32 gb
Post by monjanse »
asik1 wrote:The forum is slowwwwwwww here today
1) what grippss video you try to replicate? I want to see. i trying to to the same thing that gripps do with leaf blower effect and his other tutorial with the image braking appart:
https://youtu.be/dbHBoer5eIM?list=PLpaw ... US70cS4K2K
https://youtu.be/VTb0hG66xVU
2) Are you trying to use chroma key AND boris ? show us your attribute screen. i dont try that.
its exactly that what you showing with the picture, i try to do with graffiti.
in the begining of the video, he seems to be added himself in the background of the video with graffiti effect, with alpha on the video with graffiti effect on.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
leaf blower is all done on single track, so this is why it's on black
monjanse
ram: 32 gb
Post by monjanse »
Ok. But one of the tutorials i linked has overlay and underlay track and the overlay track has graffiti effect with alpha channel so the underlay track picture is seen where the alpha channel are. That is what i try to do, but i fail. I trying to do what you showed in the picture with pageturn effect.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Monj , what gripss might did, is applying the white mask
