help please, alpha channel doesnt work
monjanse
processor: amd ryzen 1700x
ram: 32 gb
Video Card: nvidia gforce 1070 4gb
Hard_Drive_Capacity: 445 gb
Monitor/Display Make & Model: aoc freesync
Corel programs: corel videostudio ultimate 2018
Post by monjanse »
i try to add a boris graffiti effect on a video or image, but the alpha channel doesnt work, it is just black. what must i do to fix it? i contacted boris fx, but they told me to hide background layer, but if i do that, all will be black and hide the first videotrack.
here is a video showing the problem in videostudio x8.5:
https://youtu.be/kfB4z3mJmfs
Re: help please, alpha channel doesnt work
Although I don’t use Boris that much it does seem to work ok creating animated text / titles
I am not sure from your video what the actual problem is as you do not appear to have Customised the effect nor added any text.
It may be your video files giving problems although mts types should work ok.
Have you applied any other effects / filters or just Boris?
Can you use the sample library video clips (SP-V01.mp4) to apply the filter, that way we can replicate your work. Does that go black or can you see the actual video?
If you save and zip the VSP project file you could attach to your post.
monjanse
ram: 32 gb
Post by monjanse »
i tried to uninstall videostudio and reinstall it, but now boris graffiti doesnt work at all.
have you tried re-installing Boris Graffiti again?
Is your version part of Video Studio Ultimate Bonus Pack, or have you purchased Graffiti separately?
monjanse
ram: 32 gb
Post by monjanse »
I unninstalled and reinstalled the bonus boris graffitti but it wont work now at all. I also updated biris graffiti to 6.6 but it wont work. The plugin effect only shows as a black effectbox in fx tab.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
monjanse wrote:i tried to uninstall videostudio and reinstall it, but now boris graffiti doesnt work at all.
Why have you done that? Never there is a need for reinstalling unless full understanding of a problem or collections of culprits.
Your video didn't explain what the problem, you could describe in voice what you want to do.
Panasonic X900m, VXF1
monjanse
ram: 32 gb
Post by monjanse »
i reinstalled videostudio in a hope for fix on boris graffiti. here is some pictures of that boris graffiti no longer works in the reinstalled videostudio.
it only shows a black square box in the fx's
black square box in video edit window.
monjanse
ram: 32 gb
Post by monjanse »
i found out that graffiti works if i add a preset on it then delete the preset in advance mode. but it still not in alpha when im adding forexample pageturn or 2d particle effects in graffiti.
the Boris Fx in the library should have a large G in gold.
Has this filter ever worked?
I did ask earlier “Is your version part of Video Studio Ultimate Bonus Pack, or have you purchased Graffiti separately?”
The version installed on my VSX8 is 6.1.
There is a patch a fix for Graffiti plug-in, have you applied that.
This is the link for X8 patches.
http://www.videostudiopro.com/en/support/updates/
monjanse
ram: 32 gb
Post by monjanse »
i did not purpaced graffiti seperately. it was in the bonus. it do not work correctly.
monjanse
ram: 32 gb
Post by monjanse »
the graffiti worked perfectly before, exept of that the alpha didnt worked.
monjanse
ram: 32 gb
Post by monjanse »
now i have installed the patch for boris graffiti for corel videostudiox8, but it still nothing changed. it seems that it not install correctly, even when it says it is installed completely.
Regarding version numbers, I have just installed CVSX8 and the Bonus pack containing Boris Graffiti, the version number I see is 6.1.
The question is why is your version 6.6?
I assume you are installing for 64 bit programs, however I doubt that the program would allow installing 32bit over 64? Never tried?
Have you uninstalled Boris via the Program and Features.
Then clean the program
OK
Uninstall Boris
Delete the X8 setup files from …………
C:\Program Files (x86)\Corel\Corel VideoStudio Ultimate X8 Setup Files
Then
Reset the program to its default installed state by re-naming the folder 18.0 to “18.0-old”
C:\Users\UserName\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\18.0
If you cannot find this folder type %appdata% in the Start Search box to find the roaming folder.
A new 18.0 folder will be created when running the program
Now install Boris from the X8 bonus file
monjanse
ram: 32 gb
Post by monjanse »
i had the version 6.6 bechause i tried to update graffiti on theyr homepage.
monjanse
ram: 32 gb
Post by monjanse »
i now tried the cleanup that you gave a description how to do, but graffiti 6.1 still doesnt work properly. its still a black square instead of the logo. and i also tried installing 32 bit version. and still no alpha channel in videostudio from graffiti.
