moviefactory 3 error
diablo
Post by diablo »
i burned an mpeg 2 as a dvd with moviefactory 3 se and got this error message more than half way thru the burn, the target device might have some problems please try again or reboot
5213
failed to record data to disc
error dvdr-dao-spti-2a-02-06-29-00
[14252:1:0]
i tried burning with different software it it burned to a cd so is there something wrong with MF 3 SE?
maddrummer3301
Post by maddrummer3301 »
What are the properties of the source material your trying to burn.
While in MovieFactory and on the time-line screen:
Right-Click of the video's thumbnail and select "Properties".
Then post back to the forum what the properties of the video are.
MD
diablo
Post by diablo »
file type: ntsc dvd
file size : 4,264.766 kb
duration: 4912.079 seconds
video type: mpeg-2 video,upper field first
tota; frames: 147,215 frame(s)
attributes: 24 bits, 720 x 480
frame rate: 29,970 frames/sec
data rate: variable bitrate (max. 7040 kb)
audio type: mpeg audio layer 2 files
total samples: 235,779,780 samples
attributes: 48,000 hz, 16 bit, stereo
layer: 2
bitrate 384 kbps
maddrummer3301
I don't see anything wrong with those video file properties.
Sometimes you may have to try a different method for burning
or your dvd media or burner is probmatic etc
Read this post & how to create an ISO file or DVD folers:
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=5594
Hope this helps,
MD
diablo
Post by diablo »
i thinks it the burner, but i dont have a clue what the error message means
5213
[14252:1:0]
heinz-oz
Post by heinz-oz »
What other burning software do you have installed? There may be a conflict. Any DMA plugins, InCD etc?
diablo
error
Post by diablo »
i had moved my dvd burner to a dvd enclosure connected thru a USB and it was working but after a while i started to gett the error message i wrote at the beginning of this post but i decided to put my dvd burner back in my tower and it working now, so far!
i just dont know why it wont work in my enclosure after working for a bit?
how do i get it to work in my enclosure again?
thanks
maddrummer3301
When connecting devices via USB as THOFF says if there's other devices
using usb they can take up the bandwidth.
When the device was working maybe it was connecting at usb 2.0 speed
and then problems if it dropped down to usb 1 speed.
Also if using a usb hub can make the device drop back to usb 1 if other
devices connected to the hub are usb 1. (Thanks for that info Thoff)
Maybe try a different usb port on the machine etc.
Some external boxes(controllers) are setup only for harddisks and not
cd/dvd's. Also, depends on the make & model of the burner.
When you connect the external device under system properties you may
have to disable "Write Caching & indexing", or maybe that should be
enabled if disabled.
A wild guess would be that the burner while in the computer has the
device jumper (located on the back of the drive) to Secondary or DS.
When you installed the drive in an external box maybe you didn't
change that jumper to Master (1st device in the chain of the port).
Usually when installing a single device in an external box the device
needs to be assigned Master.
MD
