Simple luminosity mask script - first attempt (UPDATED)
gbotes
Hard_Drive_Capacity: 500Gb
Corel programs: Paint Shop Pro X8, Aftershot 2
Post by gbotes »
I come from a GIMP user background, and just recently purchased PaintShop Pro x8. So far there are many things about PSP that I love, and a few things that I hate. One of the things I'm missing is the ability to create and edit simple luminosity masks. I've searched Google without much success, and found no mention of luminosity masks in any of the PSP documentation as yet. So, I've tried to come up with a script that approximates how I've worked with luminosity masks in GIMP.
In case some members of the forum find usefulness in it, here is the script I recorded - it seems to do what I had in mind and what I understand as luminosity masks. If you check it out and have suggestions, comments, tips, etc I'd be grateful.
UPDATE:
I didn't encounter "jaggies" with the first two images I edited using my first script, but I did with subsequent images. This makes it clear to me that Gimp and PSP work a bit differently as far as layers go. LeviFiction (thanks!) asked about this, and pointed out that it might occur. As a result I've revised this script by removing Threshold. I would still welcome any comments/suggestions/improvements, as this script helps but still doesn't quite seem to give me luminosity masking as in Gimp.
My script was recorded and saved in my restricted scripts folder (DriveLetter:\Users\UserName\Documents\Corel PaintShop Pro\18.0\Scripts-Restricted):
Code: Select all
from PSPApp import *
def ScriptProperties():
    return {
        'Author': u'gbotes',
        'Copyright': u'',
        'Description': u'Create light, dark and mid tone masks for editi'\
            u'ng with curves',
        'Host': u'PaintShop Pro',
        'Host Version': u'18.00'
def Do(Environment):
    # EnableOptimizedScriptUndo
    App.Do( Environment, 'EnableOptimizedScriptUndo', {
            'GeneralSettings': {
                'ExecutionMode': App.Constants.ExecutionMode.Default,
                'AutoActionMode': App.Constants.AutoActionMode.Match,
                'Version': ((18,0,0),1)
    # LayerDuplicate
    App.Do( Environment, 'LayerDuplicate', {
    # Layer Properties
    App.Do( Environment, 'LayerProperties', {
            'General': {
                'Opacity': None,
                'Name': u'Dark',
                'IsVisible': None,
                'IsTransparencyLocked': None,
                'LinkSet': None,
                'UseHighlight': None,
                'PaletteHighlightColor': None,
                'GroupLink': None,
                'BlendMode': None
            'BlendRanges': None,
            'Path': (0,0,[],False),
            'ArtMediaTexture': None,
            'Effects': None,
            'BrightnessContrast': None,
            'ChannelMixer': None,
            'ColorBalance': None,
            'CurveParams': None,
            'HSL': None,
            'Threshold': None,
            'Levels': None,
            'Posterize': None,
            'Vibrancy': None,
            'Overlay': None,
            'LocalToneMapping': None,
            'Invert': None,
            'HistogramAdjustment': None,
            'FillLightClarity': None,
                'ExecutionMode': App.Constants.ExecutionMode.Silent,
                'AutoActionMode': App.Constants.AutoActionMode.Default,
    # LayerDuplicate
    # Layer Properties
            'General': {
                'Opacity': None,
                'Name': u'Light',
                'IsVisible': None,
                'LinkSet': None,
                'GroupLink': None,
                'BlendMode': None
            'Effects': None,
            'HSL': None,
            'Threshold': None,
            'Levels': None,
            'Posterize': None,
            'Vibrancy': None,
            'Overlay': None,
            'Invert': None,
    # LayerDuplicate
    # Layer Properties
            'General': {
                'Opacity': None,
                'Name': u'Mid',
                'IsVisible': None,
                'LinkSet': None,
                'GroupLink': None,
                'BlendMode': None
            'Effects': None,
            'HSL': None,
            'Threshold': None,
            'Levels': None,
            'Posterize': None,
            'Vibrancy': None,
            'Overlay': None,
            'Invert': None,
    # MaskFromImage
    App.Do( Environment, 'MaskFromImage', {
            'CreateMaskFrom': App.Constants.CreateMaskFrom.Luminance,
            'InvertMaskData': False,
            'SourceImage': 0,
    # Vector Selection Update
    App.Do( Environment, 'VectorSelectionUpdate', {
            'Path': (1,-1,[],False),
            'Type': App.Constants.ObjectSelection.Select,
    # MaskFromImage
            'SourceImage': 0,
    # MaskFromImage
            'InvertMaskData': True,
            'SourceImage': 0,
            'Path': (1,1,[2],False),
            'Path': (1,-1,[2],False),
    # Copy
    App.Do( Environment, 'Copy', {
            'Path': (1,2,[1],False),
    # PasteAsNewLayer
    App.Do( Environment, 'PasteAsNewLayer', {
            'CreateFromDropData': False,
            'InsertPos': -1,
    # Copy
    # PasteAsNewLayer
            'InsertPos': -1,
    # LayerMergeDown
    App.Do( Environment, 'LayerMergeDown', {
            'Path': None,
            'Path': (0,1,[],False),
    # DeleteLayer
    App.Do( Environment, 'DeleteLayer', {
            'Path': None,
            'MergeMask': False,
            'WorkingMode': 1,
    # Layer Properties
            'General': {
                'Opacity': None,
                'Name': u'Mask - Mid',
                'IsVisible': None,
                'LinkSet': None,
                'GroupLink': None,
                'BlendMode': None
            'Effects': None,
            'HSL': None,
            'Threshold': None,
            'Levels': None,
            'Posterize': None,
            'Vibrancy': None,
            'Overlay': None,
            'Invert': None,
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Simple luminosity mask script - first attempt
Post by LeviFiction »
If you use the [code] [/code] tags around the script text it will maintain the necessary spacing.
Does Threshold hurt the luminosity mask at all? It doesn't make it too jagged or strict? I'll admit I've tried several times to come up with a good method for creating luminosity masks and it never once occurred to me to use threshold on the mask itself.
gbotes
Post by gbotes »
Ah, thanks for the tip abut the
Code: Select all
tags. :D
The reason I use threshold is to avoid overlap of the mask areas. It works without threshold, too, but the overlap quickly becomes apparent. It is, perhaps, a matter of personal taste whether it is better with or without it. :)
