Scripting error question: JascApp.ArrangeInvalid
- gbotes
- Hard_Drive_Capacity: 500Gb
- Corel programs: Paint Shop Pro X8, Aftershot 2
I'm trying to record my second PaintShop Pro x8 script. Part of the script involves arranging layers. The script records perfectly, but on running I encounter the following error as soon as the script reaches the layer rearrange command:
------- Command Execution Failed -----------
Command Name: LayerArrange
Error Text: The arrange command is not valid in the current program state.
Traceback (most recent call last):
File "<string>", line 317, in Do
JascApp.ArrangeInvalid: Arrange command invalid in the current state
Command Name: RunScript
Does anybody know why or have a workaround for this? I would assume that it should be possible to record and run a script that rearranges layers.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Scripting error question: JascApp.ArrangeInvalid
Honestly, I'm not really sure what causes this. You'd think PSP wouldn't execute the next command until it was ready. But whenever this pops up it's like PSP is still completing the last action.
The only reliable way to deal with it that I've found, and this is probably ridiculous, is to force the script to wait 1 second just before executing the command that tends to fail.
Cassel
- ram: 16Gb
- Corel programs: PSP 8 (JASC) to PSP 2023
If it can't execute the arrange command, is it possible that the particular image/layer selection might prevent the command from being executed correctly?
Ex: trying to move a layer down 2 level, when that would be below a background layer? or trying to move more than one layer in a PSP version that can't handle that? or ending up with no layer selected (lost of focus after deleting something, often a vector) and obviously being unable to move a layer that is not active?
Cassel
https://scrapbookcampus.com
- gbotes
Thanks for your responses. I appreciate it very much. I will try both suggestions.
- gbotes
By the way, Cassel, I've just bought your two PSP books on Amazon.com and am looking forward to start reading through them later this evening. I need to get up to speed with PSP quite quickly.
- gbotes
OK, I've tried inserting a waiting period in my script but the error remains despite a five second sleep. So, it seems it's not due to simultaneous command execution or a command still completing. Also, it doesn't seem to matter how I try to arrange the layers - one level or two levels up or down makes no difference.
I've emailed Corel support the question, and I'm hoping it's just a bug that need to be sorted out.
- ram: 6 GB
Can we see the script?
- gbotes
Sure can. It is related to the luminosity mask idea which I am still playing with. Once I've created the layers, I would like to arrange them in a sequence. Apart from this idea, though, I can see that in future I would like to use scripts to work with layers. This script is still rough - and made only using the script recorder.
Code: Select all
from PSPApp import *
def ScriptProperties():
return {
'Author': u'',
'Copyright': u'',
'Description': u'',
'Host': u'PaintShop Pro',
'Host Version': u'18.00'
def Do(Environment):
# EnableOptimizedScriptUndo
App.Do( Environment, 'EnableOptimizedScriptUndo', {
'GeneralSettings': {
'ExecutionMode': App.Constants.ExecutionMode.Default,
'AutoActionMode': App.Constants.AutoActionMode.Match,
'Version': ((18,0,0),1)
# Vector Selection Update
App.Do( Environment, 'VectorSelectionUpdate', {
'Path': (1,2,[3],False),
'Type': App.Constants.ObjectSelection.Select,
'ExecutionMode': App.Constants.ExecutionMode.Silent,
'AutoActionMode': App.Constants.AutoActionMode.Default,
'Path': (1,-1,[],False),
# MaskFromImage
App.Do( Environment, 'MaskFromImage', {
'CreateMaskFrom': App.Constants.CreateMaskFrom.Luminance,
'InvertMaskData': True,
'SourceImage': 0,
# DeleteLayer
App.Do( Environment, 'DeleteLayer', {
'Path': (0,1,[],False),
'MergeMask': True,
'WorkingMode': 1,
'Path': (1,1,[3],False),
# LayerArrange
App.Do( Environment, 'LayerArrange', {
'Path': (1,-1,[1],False),
'MoveAboveSibling': True,
'Path': None,
'Path': (1,-1,[3],False),
# LayerArrange
'Path': (1,1,[1],False),
'Path': None,
# LayerMergeDown
App.Do( Environment, 'LayerMergeDown', {
'Path': None,
- ram: 6 GB
Yeah this fails for me to.
It seems to fail because no layer is actually selected for me. Whether or not that is the case for you I'm not sure. But it would make sense. Can't arrange a layer if no layer is actively selected. Can I assume this script was used alongside another script? I notice your error shows line 317 but there aren't 317 lines in this script, and it also reports it happened in the RunScript command.
- gbotes
Thanks for looking at it, LeviFiction. The reason for the differences in line numbers is because I've made so many edits trying to understand the error, so the original error was posted from my first attempt but the code you're seeing is from later re-recording. It's not running alongside another script. But it was recorded by drag-n-drop rearrange of the layers. Records fine, but won't playback. Do you think the problem is the drag-n-drop? Is there another way to rearrange layers?
- ram: 6 GB
No, what I'm saying is that I continue to fall victim to my greatest enemy.
Jumping the gun.
There is indeed a bug with LayeArrange of some sort. I had to create an image with a layer setup that would work with the commands given in the script. Then step through it to make sure nothing ruined the state of the program. Stepping through I managed to prove to myself that it was indeed LayerArrange, and then realized I was being stupid all I had to do was record a script with a single layer arrange command than test that. So lots of silly mistakes on my part.
I have reported it to Corel.
EDIT: Just heard back they agree it needs to be fixed. Have no idea when it'll be fixed but at least they agree. xD
Jumping the gun.
- gbotes
Many thanks, LeviFiction! That makes me feel better.
- gbotes
I seem to have found a workaround for this problem. Use the Layer Menu to rearrange layers during script recording rather than drag-n-drop which seems "iffy" with layers anyway. Needs further testing to be 100% sure, but seems to work.
Could you please explain how to insert waiting period into the script???
LeviFiction wrote:Honestly, I'm not really sure what causes this. You'd think PSP wouldn't execute the next command until it was ready. But whenever this pops up it's like PSP is still completing the last action.
gbotes wrote:OK, I've tried inserting a waiting period in my script but the error remains despite a five second sleep. So, it seems it's not due to simultaneous command execution or a command still completing. Also, it doesn't seem to matter how I try to arrange the layers - one level or two levels up or down makes no difference.
