Black Screen on Preview with .MTS
manafriar
operating_system: Windows 8.1
processor: Intel[R] Core[TM] i5-4210U CPU 1.70GHz 2.40Ghz
ram: 4.00GB
Corel programs: Corel Videostudio Pro X7
Post by manafriar »
Hello,
I have been a long time user of the Corel Videostudio Editing Series and have come across this problem a few times. When using an .MTS video format,
which my JVC Quad Proof HD Camcorder records in, the Corel Videostudio X7 project previewer simply shows a black screen, and not the video. Obviously
this is frustrating and hard to work with, so are there any solutions to this? I'm currently using Corel Videostudio Pro X7 and uimporting .mts video format.
One possible cause for the black screen is the fact that I am applying a Gamma colour fix to the videos, but for the project I am working on that is
essential. Also know that the occurrence of the black screen isn't consistent. Some .mts files show a black screen in preview while others don't, not to mention
that the clips play perfectly when previewed as a clip but only show black when played as a full project.
Here are the properties of one .mts video which is exhibiting the problem:
File Name: 000002.MTS
File format: PAL HDMV
File Size: 416 MB
Duration: 145.440 Seconds
Video Type: H.264 Video, Upper Field First
Total Frames: 3,636 frame(s)
Attributes: 24 bits, 1920x1080, 16:9
Frame Rate: 25.000 frames/sec
Data Rate: Variable bit rate (Max 22599 kbps)
Audio Type: Dolby Digital Audio
Total Samples: 6,981,120 Samples
Attributes: 48000Hz
Layer: None
Bit Rate: 256 kbps
Thanks in advance for anybody who is willing or able to help me! Any assistance is much appreciated.
User of Corel Videostudio Pro X7
Re: Black Screen on Preview with .MTS
How exactly are you 'importing' the .mts media from you camcorder? Do you simply transfer the video to your computer and then open it in VS, or do you have some other workflow? Does JVC, for instance, provide any software for transferring the video from camera to computer? With some other brands, for instance, while the native format in the camera is mts, when transferred using such software it becomes .m2ts which VS normally has no problems with.
manafriar
ram: 4.00GB
Post by manafriar »
Thanks Ken, that was exactly the problem. I needed to transfer the files using the JVC's software.
Much appreciated! :D
