VSX8 Rendering Issues
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
I am currently working on a project comprising of over 1000 images with a run time of approx 2 hours, because of the estimated size of the completed project, about 8GB, I split the project into 5 sections, completing and rendering each section.
For rendering I used MOV 1920x1080 30fps for saving to USB and TV playback
The first 3 sections rendered successfully without issue, however the 4th section, run time of about 17 mins. kept crashing, I tried 4 times to render with the crash appearing at different times, 41%, 42%, 67% and 76% so there was no consistency.
The error however was exactly the same for each crash
Corel\Corel Video Studio Ultimate X8\upscaling.dll
Upscale.cpp
Line 615
Expression: Succeeded (1Hr)
See Visual C++ documentation on asserts
So I tried splitting the project at about halfway, then tried rendering again, this time both parts rendered successfully and when joined together you cannot tell that that the 2 parts had been rendered independently.
This indicates that there was nothing wrong with the original 17min. project, so can anyone explain the cause of the crash
Now I only need to complete the 5th section and put it all together
Robert
Re: VSX8 Rendering Issues
Hi Robert
Sorry I have not heard of that error message before.
I assume all project properties are the same for all projects.
If you now try rendering the 4th section again, I assume it still crashes each time.
Upscaling seems to indicate increasing sizes usually a video unscaled to play on HD tv.
So is it referring to increasing the image size.
Are all 1000 images the same size, as in resolution, width x height in pixels.
Otherwise are you able to create a Smart Package of the 4th section so we can test?
I will be away over the coming weekend so may not reply till Monday?
RobertOZ
Post by RobertOZ »
Hi Trevor,
I am creating this video for a friend just back from Canada & USA who has no idea on our to make an interesting presentation of the trip
Unfortunately, he had his camera settings wrong, so all images are 4:3 aspect, 3648x2736 res. 300 dpi with a bit depth of 24, so I had to use fit project size to obtain a widescreen format.
Originally, I had the whole project in the timeline, but found it was becoming unmanageable, so I just kept splitting the project into sections and saving each section with a new name so project settings for each section should remain the same.
I selected MOV 1920x1080 30fps as the rendering format, because I know this will play on his TV
Smart package VSP file attached in zip file
Thanks for looking
Robert
1st Stop Canada.zip
(39.99 KiB) Downloaded 198 times
canuck
operating_system: Windows 8.1
Post by canuck »
Are we supposed to see anything since all that seems to be in the zip file is the vsp project file. That is not the SmartPackage
RobertOZ
Post by RobertOZ »
Oops, sorry about that, uploading to dropbox, will provide link when upload complete
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
Robert, why you didn't batch resized the photos before you started this mega saga?
Panasonic X900m, VXF1
RobertOZ
Post by RobertOZ »
asik1
Having had issues with batch resize in the past, I really did not give it a thought, certainly will use it for the final section of the project
Canuck,
Whilst I have uploaded the Smart Package to Dropbox, I need to obtain the permission of the owner of the images to share them, I am sure that Trevor normally only requires the .vsp file, because that still shows how the project was constructed
stevef
motherboard: Z2MiniG4
processor: Intel Xeon E-2174G at4GHz
Video Card: Radeon Pro WX 4150
Hard_Drive_Capacity: 10tb
Monitor/Display Make & Model: Visio Television
Corel programs: All Videostudio Ulead to Corel VS2021
Post by stevef »
Microsoft Visual C++ Runtime Library error still occurring in Videostudio 2019. This crash issue is caused by an incompatible object to the output settings. This could entail a placed video or image or the actual project size. Upscale.cpp is the culprit. This was not an issue with older versions of Videostudio...
Solution: Ensure that both the project size and any placed media are all the same resolution/format for output.
Issue: Rendering 1280x720 to 1920x1080 may cause crash, as will other formats.
