Extracting audio from video
agal1057
motherboard: asustek p8z77-v deluxe
processor: sandy bridge intel i7-2700k 4 cores 3.5 ghz
ram: 32gb
Video Card: Nvidia geforce gtx550ti
sound_card: could not find info
Hard_Drive_Capacity: 4tb
Monitor/Display Make & Model: samsung s27c390
Post by agal1057 »
I am wondering if its possible in vsp X8 ultimate to extract the audio from a video file to use it in the project on a different clip
thank you.
canuck
operating_system: Windows 8.1
Re: Extracting audio from video
Post by canuck »
With the video on the main timeline, select Share and then select Audio to create a separate audio file
agal1057
ram: 32gb
Post by agal1057 »
I'm sorry but I can not figure it out, are we talking about extracting the audio on only one of the video clips in the timeline because that is what I need, when you say go to share, I do not see any options for sound on the share tab, is there another way to share than the top share tab?
thanks
canuck
Post by canuck »
In the Edit mode, insert a single video on the timeline from which you want to extract the audio
Then select share and you should get the following screen and then select Audio.
If you have multiple video clips on the timeline then I think the audio is extracted for the whole project
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
No need to extract audio, just put the clip in an overlay track , size it to minimum and place it out of frame.
Panasonic X900m, VXF1
canuck
Post by canuck »
Size what to a minimum? Place what out of frame? How does that extract the audio from a video clip?
I have no idea what you are talking about. You have to explain what you are doing a lot better. Just a few words don't explain it at all.
Hartmann
motherboard: asus 990fx r2.0
processor: amd 8 core
ram: 16mb
Video Card: nvidia Geforce GT 740
sound_card: Turtle Beach Santa Cruz 24 bit
Hard_Drive_Capacity: 6tb
Monitor/Display Make & Model: Acer x553w
Corel programs: 4
Post by Hartmann »
Drop your clip into the timeline. Right click and choose split audio. Done
canuck
Post by canuck »
Hartmann wrote:Drop your clip into the timeline. Right click and choose split audio. Done
THen how do you get that audio to a new project?
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
canuck wrote:THen how do you get that audio to a new project?
When I want to use the audio from a video file on a different clip, I simply put the video file on an audio track where I want it. Once a video file is placed on an audio track, Corel treats the video file as an audio file.
agal1057
ram: 32gb
Post by agal1057 »
thanks to all, I did find the right click and split audio option very easy to use and it does exactly what I want, put the audio file in the audio time line and then you can position the audio wherever is needed in the timeline, no hassle at all
agal1057
ram: 32gb
Post by agal1057 »
If you want to export the sound file to another project just drag the file into the samples panel and from there you can drag it down to where you want to use it, I hope this helps
Once you Split Audio a sound clip is placed on the lower track, the video clip is muted.
The Audio clip is a virtual clip and part of the video file, it is not a separate file.
Take care of the video file, if you remove the video from the hard drive then you will loose the audio clip as its still part of the video file, if that makes sence.
