Transitions alter clip length
dbsanders
motherboard: ASRock Z97 Extreme4
processor: i7 4790K
Video Card: GeForce GTX 750 TI
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: HP 2311x
Post by dbsanders »
Probably a real newbie question, but I cannot seem to find a good answer and don't know why more people don't mention this.
My first project is a music video-type project, with a music track that has to be in sync with the video (obviously). My video consists of one large .mov file, which I am splitting up by scene to add transitions.
I'd expect a 1-second transition to start .5 seconds before one clip and last .5 seconds into the next clip, right? When I add a transition, it seems to cut out part of the first clip, inserting the transition in its place. Then from that point on, my video is ahead of my audio.
I've seen solutions like manually lengthening the clips to compensate, although I cannot seem to figure that out quite yet. But why does one have to do this? Why would adding a transition alter the length of the clips at all? I don't remember this issue in other video editors.
Thanks,
Bret
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Transitions alter clip length
Post by asik1 »
That's the way VS works. We all know it and edit accordingly.
Few other software allow the user to choose transition point as start/center/end. sadly not VS.
Panasonic X900m, VXF1
Hi Bret
When we add a transition the two video clips are overlapped by the length of the transition, this effectively reduced the length of the video track,
Your best option is to render the project to same properties as your video clips, that will combine the audio to video.
Using the new video cut and apply your transitions.
There may be workround s…
1 / by increasing the length of one of the clips by the same as transition duration, then applying the transition.
2 / cut the top track to create a 2 second clip, right click and Copy, drop on the overlay track, position below original, Right click preview screen for Fit to Screen then add 2 second transition to this clip on overlay track, set default transition durations via F6
Tip – use fit to Screen via F6 Edit tab ( Preferences) no need to fit to screen?
dbsanders
processor: i7 4790K
Post by dbsanders »
Thanks, that does make sense, I wasn't thinking about it in the right way. I used to use Cyberlink PowerDirector and didn't remember this happening, but it's possible I didn't do this type of project, with a constant audio track and a strict sync requirement.
Thanks guys/gals!
