mass duplication of vector shape along a curve/circle
Torrianthane
operating_system: Vista Ultimate
motherboard: Acer EM61SM-EM61PM
processor: AMD Athlon 64 X2 Dual Core 3800+ 2.00Ghz
Video Card: NVIDIA GeForce 6150SE nForce 430
sound_card: High Definition Audio Device
Hard_Drive_Capacity: 54.21 GB
Monitor/Display Make & Model: DELL 2208WFP 22.0"
Post by Torrianthane »
Hello,
I am trying to vector-replicate a coat-of-arms type seal from a lower resolution image and part of this emblem I am duplicating has an outer perimeter floral/leaf pattern that repeats around an outer circle (there are approximately 200 of these flower -or leaf type elements strung together in a circle). I know how to get text to follow a vector curve or circle, but is there any way of having not-text vector elements repeat easily and follow a circle so that this pattern mentioned above can be replicated (without hours of manual vector input for each instance of the element)?
Thanks.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: mass duplication of vector shape along a curve/circle
Post by LeviFiction »
Not an easy way, no. PSP's vector tools are simple and limited. You can do a lot with them, but they aren't meant to make large patterns or anything like that.
If it's just a perfect circle then you might be able to do it. But again not quickly. The method involves using Layer Duplicate to duplicate the vector object (leaf in your case) and moving the pivot point of the object to the center of the circle. Then, slowly duplicating the leaf, and rotating each new leaf a specific number of degrees around the circle. This takes a little bit of time. But with shortcut keys it's pretty easy.
This should be technically possible inside of a script to really speed it up but when using rotate it does weird things in scripts. Its like it ignores the pivot point inside scripts. Very weird.
No, for things like this I recommend an external editor. Programs like Inkscape can do what you want. And if you want to use the vector inside of PSP after you've made it inside of Inkscape all you have to do is export it from whatever program you use to an EMF file. PSP can read EMF and leave it editable unlike the SVG format.
