I am having problems in X8 with brushes.
When used continuously the brushes keep skipping impressions every now and then. This is particularly noticeable with directional brushes.
This seems to be also when they overlay the edges of images on layers below as if they are "reading" them ..very spooky!
The problem is intermittent but particularly bad with Vector stroke and vector paint scripts.
Can anyone help?
X8 brush problem
Cassel
- ram: 16Gb
- Corel programs: PSP 8 (JASC) to PSP 2023
Re: X8 brush problem
Did you check the Brush Variance Palette? Are all the settings back to Normal or 0% Jitter?
You get the Brush Variance Palette with F11.
Cassel
https://scrapbookcampus.com
JudyM
- processor: 3.40 gigahertz Intel Core i5-4670
- ram: 2048 MB
- Hard_Drive_Capacity: 999.36 GB
- Monitor/Display Make & Model: HP L1706
- Corel programs: PSP 9,X, X4 - 2018
Thanks for your reply, Cas.Cassel wrote:Did you check the Brush Variance Palette? Are all the settings back to Normal or 0% Jitter?
I double checked all settings including brush variance and all seems OK.
[img src="https://picasaweb.google.com/lh/photo/Y ... directlink"][/img]
In this image I have placed three "brush" layers above a vector layer. The only variance that the brush has is rotation "direction"
If I click, hold down the shift key and click elsewhere, I get gaps.
If I freehand over vector images below, I end up with incomplete impressions. The circular attempt was using Vector stroke script [vector paint gives a similar result]
[img src="https://picasaweb.google.com/lh/photo/X ... directlink" width="750" height="500"][/img]
JudyM
- ram: 2048 MB
I have sorted the problem by ticking "smart edge" on and off again a couple of times
Although it was unticked it was still functioning
Judy
