Aftershot 2.2.1 wont start under Gentoo
deranonyme
operating_system: Linux
System_Drive: N/A
Post by deranonyme »
When I try to start Aftershot with the wrapper script /usr/bin/AfterShot2X64 I get the following error message:
Code: Select all
Install Path:           /opt/AfterShot2(64-bit)
LD_PATH:                /opt/AfterShot2(64-bit)/lib:
XLIB_SKIP_ARGB_VISUALS: 1
Fatal: This application failed to start because it could not find or load the Qt platform plugin "xcb".
Reinstalling the application may fix this problem.
Reinstalling doesn't fix the problem. It also uses the installed qt5 libraries from the system and not from the package.
Any hints?
dFlyer
System_Drive: N/A
Re: Aftershot 2.2.1 wont start under Gentoo
Post by dFlyer »
Try this link:
http://forum.corel.com/EN/viewtopic.php?f=94&t=57338
It's under bug and works with Ubuntu.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
deranonyme
System_Drive: N/A
Thanks for the hint but it didn't work for me.
johanthor
System_Drive: N/A
motherboard: Gigabyte GA-Z77 DH3
processor: Intel 2600K
ram: 24 Gbyte
Video Card: Nvidia 660 GTX
sound_card: Soundblaster Audigy
Hard_Drive_Capacity: 512 Gbyte
Monitor/Display Make & Model: HP ZR24w
Post by johanthor »
deranonyme,
ASP and Gentoo user here, so in some way we'll make it work :)
First, what does
Code: Select all
$ locate libqxcb
say?
(the locate command is given by package sys-apps/mlocate, and you'll need root to run updatedb first)
On my system I have the following:
Code: Select all
/home/<user>/.dropbox-dist/dropbox-lnx.x86_64-3.8.6/plugins/platforms/libqxcb.so
/opt/AfterShot2(64-bit)/lib/plugins/platforms/libqxcb.so
/opt/dropbox/plugins/platforms/libqxcb.so
/usr/lib64/qt5/plugins/platforms/libqxcb.so
Based on your description, I think that's the file we need to make sure ASP finds.
Other than that, do you have
Code: Select all
x11-libs/libxcb
installed?
Johan
deranonyme
System_Drive: N/A
Thanks for your support.
libqxcb is installed.
Code: Select all
# locate libqxcb
/home/frank/.dropbox-dist/dropbox-lnx.x86_64-3.8.6/plugins/platforms/libqxcb.so
/opt/Pixum/Pixum Fotowelt/platforms/libqxcb.so
I think AfterShot's start script doesn't work properly on Gentoo and doesn't give access to the libraries installed by AfterShot itself.
johanthor
System_Drive: N/A
ram: 24 Gbyte
Post by johanthor »
Hm, strange as it works here on my Gentoo-box... A silly question: how did you install it, via deb or rpm?
deranonyme
System_Drive: N/A
I used a renamed ebuild from http://gpo.zugaina.org/media-gfx/aftershotpro/ChangeLog
Maybe there is a path variable not correct.
johanthor
System_Drive: N/A
ram: 24 Gbyte
Post by johanthor »
If the /usr/bin/AfterShot2X64-script is somehow corrupt, you could diff it from my version, available here:
http://pastebin.com/nCbSdh5T
I didn't know of that ebuild, but I see it downloads official builds, so it seems correct. But what if you try to download the rpm from Corel's site
http://www.aftershotpro.com/en/support/updates/
and install it by
Code: Select all
sudo rpm -i --nodeps path_to_aftershot-file.rpm
(rpm is in app-arch/rpm by the way)
Does this work for you? The nodeps switch isn't beautiful, but since you got it installed by the other ebuild, you should already have the necessary dependencies installed.
deranonyme
System_Drive: N/A
The hint with the rpm-installation was helpful. Now it works correctly. But it would be interesting to know the reason for the problem with the ebuild.
johanthor
System_Drive: N/A
ram: 24 Gbyte
Post by johanthor »
Glad to see it worked out. I didn't test the ebuild, and won't probably neither now :D
If you find some differences, please report back...
When a new version comes out, I usually remove the previous one by
Code: Select all
rpm -e name_of_package
and install the new one as above. Perhaps upgrading works, but it didn't before and it's too difficult to change :roll:
Best regards,
Johan
