I had to reinstall today and find when I go to full size with an image the file name no longer appears at the top border beside the Program Title, "Corel PaintShop Rro X7"
Does anyone know where this great feature is hidden away???
Thanks, Jim
In my PSP the file name does not appear next to the Paint Shop Pro version at the top when I use the Zoom to 100% option (which I would consider viewing the image full size). It only appears when I click on the Maximize icon (next to the red X in the image window's titlebar) to maximize the window so that the image window fills the workspace and loses its titlebar and the border around the image. As far as I know there is no setting for this - it just happens.
JobB's description is better than mine I tried that and it does work but not reliably and not the behavior I saw before...
Before if I had multiple images in non-tabbed view and sorted so that they all sized to fill the workspace. Then I clicked on a single images Maximize button it filled the screen and the file name appeared at the top. However, within the border of the image it still had the Restore and Close icons showing???
Jim, If I understand you correctly the restore and close buttons are still there but they are in a different place. Now they are located directly under the program's Minimize/Restore/Close buttons.
In the below example I had three images open in non-tabbed view and I maximized one of them.
click for larger view
Above example is in PSPX8 but it looks the same in X7.
That is strange Jim. I even fired up PSPX7 to make sure we were comparing apples to apples. . .
Click for larger view
Resetting your workspace "might" help as it seems to cure all sorts of things. Here are some instructions. It mentions X6 but the process is still the same for later versions. Note that if you select Option 2 (holding down the Shift key) your file locations will need to be reset whereas in Option 1 you can avoid this.
I just checked X4, X5 & X6 and you're correct; X7 was the first version to have the file name next to the program name. On a side note, X4 didn't allow you to restore once you maximized as it would automatically switch you to tabbed mode. I seem to remember a lot of users complaining about that.
If for any reason you need to uninstall again, try using the cleanup tools provided by Corel to see if that makes a difference. You can find them here http://forum.corel.com/EN/viewtopic.php?f=56&t=52337 I don't know if that will make a difference or not but it will clean out anything the program leaves behind. Sorry I didn't think to tell you earlier.
Do you see the image titles in Tabbed mode? That is actually my preference as I can easily click on the one I want.
X3 has the Title at the top of the windowed image and also on the PSP version bar as well. Maximising the image the PSP version bar also then shows the scaling % as well.
hartpaul wrote:X3 has the Title at the top of the windowed image and also on the PSP version bar as well. Maximising the image the PSP version bar also then shows the scaling % as well.
LindaSue wrote:All versions prior to X4 show the file name on the title bar. I don't have X3 so I don't know about that version. X2 and earlier all have it.
And yet you can see from my pictures it is not present...
It was before I had to do a re-install.
I have never seen it before and I started with PSP 7.
So in the NX series, there must be a setting??? Or at least one would not think it is up to a roll of the dice
