Ubuntu 14.04 CRASH
Bugs & Suggestions
Ryba
operating_system: Linux
System_Drive: N/A
motherboard: ABIT IP-35E
processor: Intel
ram: 6GB
Corel programs: Aftershot pro 2
Ubuntu 14.04 CRASH
Post by Ryba »
Hi all,
I have a problem with starting Aftershot PRO on my ubuntu system, after run i have window with this message:
A problem occurred the last time AfterShot 2 was running. For example, a corrupt or unreadable file might have caused the application to shut down.
Do you want AfterShot 2 to return to the last set of files you were working with (Resume) or do you want to clear the last action (Cancel)?
When click resume or cancel nothing happend.
Run from shell:
./AfterShotPro: error while loading shared libraries: libOpenCL.so.1: cannot open shared object file: No such file or directory
It seems, that some libraries are missing to run Aftershot.
Here is .aftershot log:
Code: Select all
0.0: I have SSE2
0.3: Bibble program arguments ("./AfterShotPro")
0.3: Loading plugins
0.8: AfterShot2 Pro New key used. 20
0.8: System locale: en_US
0.58: AfterShot2 Pro New key used. 20
0.95: AfterShot2 Pro New key used. 20
0.99: AfterShot vers.: 2.2.1.64
0.99: Built on: "pá čvc 24 2015"
0.99: Language: en
0.99: App Path: /opt/AfterShot2(64-bit)/bin/AfterShotPro
0.99: System Home: /opt/AfterShot2(64-bit)/supportfiles
0.99: User Home: /home/ryba/.AfterShot
0.99: Prefs Home: /home/ryba/.config/Corel/AfterShot Pro v2.conf
0.99: Platform:     Linux
0.99: Issue: "Ubuntu 14.04.3 LTS \n \l"
0.99: Kernel: "Linux version 3.13.0-62-generic (buildd@lgw01-59) (gcc version 4.8.2 (Ubuntu 4.8.2-19ubuntu1) ) #102-Ubuntu SMP Tue Aug 11 14:29:36 UTC 2015"
0.99: Build Mode:   Release
0.99: Product Name: "AfterShot"
0.99: AfterShot2 Pro New key used. 20
0.99: Registered Version
0.101: AfterShot2 Pro New key used. 20
0.104: Initializing
0.105: Cpu Manager init: 4
0.105: ****	Making CLManager
0.105: Got 0 platforms
0.105: OpenCL is disabled in low mem mode
0.105: "Could not select an OpenCL platform"
0.105: ****	CLManager not initialized
0.105: tileSize: 512
0.105: "MemTotal:        6111300 kB"
0.105: Memory:  3
0.105: ====================================================
0.105: Asset: 2147483647 purge
0.106: ====================================================
0.106: Heavy Asset: 2147483647 purge
0.106: NoiseEngine: 150 purge
0.106: NoiseEngine: 75 cache (50 min)
0.106: Histogram: 24 purge
0.106: Histogram: 12 cache (12 min)
0.106: PluginData: 9 purge
0.106: PluginData: 9 cache (8 min)
0.106: ImageMaster: 600 purge
0.106: ImageMaster: 300 cache (50 min)
0.106: NContainer: 2147483647 purge
0.106: Path: 2147483647 purge
0.106: Path: 2147483647 cache (2147483647 min)
0.106: RawData: 25165821 purge
0.106: UncompressedRawData: 9 purge
0.106: UncompressedRawData: 9 cache (8 min)
0.106: Version: 600 purge
0.106: Version: 300 cache (50 min)
0.107: PerfectlyClear: 6 purge
0.107: PerfectlyClear: 4 cache (4 min)
0.107: ====================================================
0.107: TileStack: 24 purge
0.107: TileStack: 12 cache (12 min)
0.107: StackTile: 3000 purge
0.107: Created 626 buffers of 857472
0.298: FALLBACK to 1252 tiles
0.298: ====================================================
0.298: BImageTile: 1800 purge
0.298: BTiledImage: 2147483647 purge
0.299: ====================================================
0.299: RegionImageTile: 3000 purge
0.299: Allocate Asset manager
0.300: Option group -  ""  - already contains an option with name -  "TIFFTAG_AFMODE"
0.300:   Option was not registered.
0.300: Option group -  ""  - already contains an option with name -  "TIFFTAG_FLASHMODE"
0.301: Globals: systemhome /opt/AfterShot2(64-bit)/supportfiles
0.301: Globals: userhome /home/ryba/.AfterShot
0.301:
====================  Plugins  =====================
      Name:
Identifier:
   Version: 1.0.0
      Path:
      Name: Black and White
Identifier: com.corel.BlackAndWhite
   Version: 1.0.0
      Path: <System Home>/plugins/Black and White.afplugin
Identifier: com.corel.equalizer
   Version: 1.0.5
      Path: <System Home>/plugins/Equalizer.afplugin
0.391: LensDB  inserting camera Panasonic Micro 4/3 DMC-GF3 failed
0.392: /home/ryba/.AfterShot/bibbledebug
0.395: AfterShot2 Pro New key used. 20
0.398: Creating main window
0.400: AfterShot2 Pro New key used. 20
0.403: Starting Catalog Manager
Ryba
