i already rendered my video with videostudio 7 se and found out that i need to cut a few seconds off the end of the video before i burn it to DVD..
i keep trying to cut off the end and save it but it saves the whole video including the part at the end i dont want, how do i cut the end off and is it possible to cut it off without rendering it again
thanks
already encoded( rendered) and need to cut 4 seconds off
When you say rendering, Do you mean ‘Share Create Video file’
You cannot remove frames and create a new file without re-rendering.
But the process should not take that long provided your project properties are the same as your clip properties.( not sure if VS 7 supports ‘Smart Render’ )
You are using VS 7
1 / Start a NEW project
2 / You need to make the project properties the same as your video properties
I cannot remember if this option is part of V7
File-preferences-show message when inserting first video….that makes it easy!
3 / Insert the video clip you have rendered
4 / Cut the offending frames
5 / Share create video Same as Project Settings?????
It should be possible with minimum rendering, but I have not used VS 7 for a while.
Upgrade to VS 9.
Trevor
You are using VS 7
Upgrade to VS 9.
Trevor
