swap face
vasilis
- sound_card: nvidia GTX 2060
- Hard_Drive_Capacity: 500 gb
- Monitor/Display Make & Model: ASUS G731GV
- Corel programs: VS 2020
swap face
with PSX7 can i swap face to another head or transfer a head to diferent body?
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Re: swap face
Select the new head you want to use, copy it, then paste it as a new layer on the image where the body you want to use the face on exists. Then position the head over the existing head on that body. Then use whatever tools are necessary to resize, clean up, etc., the new head. Experiment with the feathering used in the selection of the new head. While all that might sound reasonably simple it comes with some caveats. If the new head is a different size than the one it replaces then resizing can create some artifacts. Is the new head in the correct perspective as the one it is replacing? There is also the problem of whether or not the lighting on the new head matches the lighting on the body you are moving it to (shadows, etc., need to match). This last issue can be addressed to some extent by using tools/brushes that lighten areas that need lightening and darkening areas that need darkening to simulate shadows, but that can be finicky work. A plugin like Nik Viveza that using control point technology can be helpful for that type of work also, but burn/dodge brushes in PSP can work also.
JoeB
Using PSP 2019 64bit
JoeB
vasilis
Re: swap face
and how can change the face only?
JoeB
- ram: 8 GB
Re: swap face
If the face is on its own layer then any editing you do on that layer only changes the face. I did say to paste the face as a new layer on the image which has the body you're going to use the face on.vasilis wrote:and how can change the face only?
JoeB
JoeB
vasilis
Re: swap face
sorry i'm c onfused.you told em above about teh head.i'm asking about two issues:replace face with another and change full head in a body.is the same process?
BJC
- Hard_Drive_Capacity: 1TB
- Corel programs: Videostudio X10 and 2020
Re: swap face
YES the same, why do you not try and you will see
vasilis
Re: swap face
οκ thanks.also i have post a question about PSX7 and text.can you help me?
BJC
Re: swap face
Your question about text is answered in the videostudio forum
vasilis
Re: swap face
the answer concerns video studio ..can you help me with PSX and what want to do?regardless of the VS
BJC
Re: swap face
No I do not do moving pictures in PSP - I would use a video program
vasilis
Re: swap face
is it possible or not?
